Old 06-02-2003, 02:57 AM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
Lightbulb HOW TO lower the ride height
hi af people,
As I have seen few people asking about how to "dropping" LOWERING the ride height of a model car, I think it is useful to share the technique I used.
The pics below are illustrating how to lower the front suspension part of Fujimi S14/S15 and Integra DC2. Please accept that the pics is hand drawn, and is not in scale, but hope it can help you.
cheers,
Joe
Old 06-02-2003, 03:13 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Great How-to!
I will use this method in the future.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 06-02-2003, 04:08 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
Fantastic mate, very helpful.
You mentioned that the How-To was for the front suspension, can this method be used for the rear? If not is there any chance of a How-To for the rear suspension? Thanks again.
Old 06-02-2003, 05:10 AM
joecwlaw's Avatar
for the rear susp part, it would be using the similar technique. However, the bottom part of the suspension arm varies from kit to kit, but it would be the same as for the front susp ( THAT IS to make the arm towards upside instead of lowside. (tough to explain))
Old 06-02-2003, 05:43 AM
gundam1969's Avatar
gundam1969 gundam1969 is offline
AF Vendor
Send a message via AIM to gundam1969
Great info :
Thanks,
:bandit:
Old 06-02-2003, 11:02 AM
Murray Kish Murray Kish is offline
Getting Old...
Joe,
Nice how-to and drawings. Crystal clear!!
Thanks
Murray
Old 09-21-2003, 05:22 PM
fujimituner235's Avatar
fujimituner235 fujimituner235 is offline
Send a message via AIM to fujimituner235
good technique!
"I like you...but you're crazy.....you're crazy man" -Will Ferrell (old school)
Old 11-10-2003, 09:17 PM
dori corolla's Avatar
dori corolla dori corolla is offline
Re: Technique to lower the ride height
thanks a heap for this!
i have lowered most of my cars but they all look shit because i just took the springs out.
i will HAVE to use this method for my next cars.
"The attitude towards making things, uncompromisingquality, the
wieght of history cultivated... these are all inevitable elements for
the best products. An excellent product, which is created with
uncompromising research and endless passion. Unique ideas and
techniques made impossible things possible. Taking in your hands
and comparing, everyone will be amazed at the level of clompleteness"
Buddy Club
Old 11-10-2003, 09:29 PM
joecwlaw's Avatar
Re: Re: Technique to lower the ride height
you welcome man.
I just knew the diagrams are working again. I made the diagram 6 months ago as a lot of ppl here wonder how to lower their Fujimi cars. Let me know if you need other help.
- Joe
Old 11-11-2003, 07:50 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Great how to. Very detailed drawings, and explains it very well.
Old 11-23-2003, 05:22 PM
DJ RaYgU's Avatar
DJ RaYgU DJ RaYgU is offline
so this would work for the Veilside S14 also?
Current Project:
Fujimi Veilside Combat Silvia S14...almost finished
Old 11-23-2003, 06:23 PM
bah humbug's Avatar
Why don't you check?
It probably will.
Sorry for being rude but sometimes you have to do you part of your work to.
Joeclaw gave you the tutorial, you lucky enough to get the tutorial now it's your turn to do you job. You can't expect to have everything handed to you.
Old 11-23-2003, 07:03 PM
joecwlaw's Avatar
All the Fujimi S14 and S15 series share the same chassis. So my tutorial works for the veilside.
Old 03-17-2004, 12:18 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
To make lowering the chassis even easier, if slightly less to-scale, try this:
Instead of cutting and swapping and regluing the suspension arms, simply extend the 'pin' at the bottom of the steering spindle, the one that meets the lower suspension arm and allows it to pivot. This will let the spindle, and thus the wheel, raise up into the fender when you trim the spring, but it will still keep everything lined up with the lower suspension. Simply take up the slack with some small washers or spacers made of styrene, so the wheel doesn't droop when you pick the model up.
This method shouldn't look too out of place, if at all, for most cars and anything buy a radical drop.
Old 04-29-2004, 01:22 AM
battousai2004 battousai2004 is offline
will this method work on the civic?
