Old 11-20-2011, 05:03 AM
euro_z's Avatar
euro_z euro_z is offline
Re: 1/43 1950 356 cab conversion
this is crazy! very nice work!
Old 11-20-2011, 06:03 AM
DominiqueBeerts's Avatar
DominiqueBeerts DominiqueBeerts is offline
Very nice indeed.
Can you tell more on the working hinges you made for the doors and hoods? Did you make your own hinging mechanism or did you improve the kit parts? I can imagine that it is not an easy task on this scale.
Furthermore, how did you solder the brass parts onto the white metal? It is known that white metal will melt rapidly, so what is the maximum heat you can use on this material?
Best regards,
Dominique.
Feel free to browse through my photo albums
Old 11-20-2011, 07:29 PM
914joe's Avatar
914joe 914joe is offline
Dominique, I made most of the hinges. For the front trunk I used the hinges from the kit and soldered .005 tubing to the body. I also add some bondo blocks inside the body that the hinges rub against to make some friction to hold the lid up. The rear lids hinges were replace with copies I cut from brass sheet and made a c channel that I used to mount to the body. The doors I first made up some door jambs. To those I add a piano hinge made from 4 peices of .005 tubing soldering 2 peices to the jamb side first. Then I drill holes in the door where the hinge parts will meet. I then take the 2 peices of tubing that will mount to the door and add some drips of solder. Then I pin those tubing peices to the other peices on the door jamb and hang the door lining up the drilled holes with the solder drips. Then add enough heat to through the holes in the door to join the hinge peices to the door without fusing the entire hinge together. I hope this makes some sence
The maximum heat you can use will depend on the thickness of the material. I use a 40watt iron and will add heat to the brass and use the molten solder to heat white metal and not the iron.
Old 11-21-2011, 01:26 PM
ianc911 ianc911 is offline
Inspiring build. Great workmanship!
ianc
Old 11-21-2011, 02:15 PM
Ok, I think I get it. Thanks for the explanation.
Best regards,
Dominique.
Old 11-23-2011, 06:48 AM
LeeABC's Avatar
LeeABC LeeABC is offline
Lovely model and very classy modelling. I like your approach, if the kit part is poor or missing make your own. I try to work the same way, the results will hopefully be worth all the extra effort.
Cheers,
Lee.
Old 11-23-2011, 06:54 PM
Helico's Avatar
Helico Helico is offline
Impressive. Movable steering in 1/43 scale is no easy feat. Looking forward to seeing the interior.
Old 11-23-2011, 10:30 PM
914joe's Avatar
Lee, I like your approach too... I used your hinge technique for making hinge supports by folding sheet brass I saw on your GTO build
Yup... The steering is a little tricky getting the linkage right. Hooking it all up at the end is going to be a pain.
Here's a pic of the Bosica wheels from the kit. I polished the hub caps and I'm using whitewalls I got from a diecast.
Old 11-24-2011, 07:44 AM
LeeABC's Avatar
Joe, the wheels look amazing quality, are they resin centres on turned rims?
I was considering giving modelling a rest after my DBR1 build but quite like the idea of trying a 1/43 project; how's the quality of the bosica kit?
Cheers,
Lee
Old 11-28-2011, 06:38 PM
914joe's Avatar
Lee, The wheels have turned rims with formed photoetch centers. Those wheels are awesome!!! The quality of the parts in the Bosica kits is great. They come with alot of photoetch parts, many turned parts, nice white metal castings and brass or nickel for the doors & lids. There are fitting issues with the doors and I end up replacing the floor. Considering that they are @ 30 years old now they are great. There has been a few updates on this kit over the years with subtle body changes and better detail on some of the parts. If you ever end up building a 1/43 356 I have molds for some improved parts.
I finished detailing the motor this week. I'm happy with how it turned out but a little dissapointed with how crowded it became once everything is in place. I had carb linkage to install but ran out of room. All the inginition parts need to be a hair smaller next time.
Old 11-28-2011, 06:45 PM
Unbelievable! I'd like to see a shot of that motor next to a quarter or something for scale.
ianc
Old 11-28-2011, 06:52 PM
914joe's Avatar
A quarter is too big Here's a pic of another motor next to a penny
Old 11-28-2011, 06:57 PM
F1Tommy F1Tommy is offline
Amazing work Joe, that motor is a work of art. Any Pan am cars in the works?
Tom Tanner/Scale Designs/Ferrari Expo 2012-Chicago March 2012
Old 11-28-2011, 07:13 PM
914joe's Avatar
Hi Tom, I'm planning on doing the #159 Fletcher Aviation car from 1953. I may end up doing the #160 car too. There is a pit scene pic of the 2 cars with their motors out and being worked on in the dirt. I'd like to model the whole scene but I'll start by doing the 159 car first.
Old 11-28-2011, 07:28 PM
Sounds very cool. Don't forget to add a few palm trees. I think they make
some real nice ones in 1/48th scale for military scenes.
FOR SALE 1991 Crew Cab The cab scarycary Cars/Parts for Sale/Exchange 0 06-24-2010 11:50 AM
1993 Dodge Dakota extended cab Jayr37A Dakota 1 04-22-2010 07:04 PM
1967 Mustang Gas to Electric Conversion 1967mustang Performance 4 11-12-2009 11:23 PM
1995-200? Lumina (GM) radio LED conversion saxonmor Car Audio 0 03-01-2009 10:59 PM
Finished : 1/43 Talbot Lago T26GS - Le Mans 1950 winner (Starter) Sennake Completed Projects / Gallery 2 01-18-2006 05:35 PM
