Old 05-26-2011, 11:31 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Re: Transmission Noise
Originally Posted by j cAT View Post
read posting #4 again !
Thanks for reminding me j_cat. Since this seemed to be the most likely suspect, I took it to the transmission shop to have them replace the bushing. However, they put it on the rack, took off the driveshaft and said everything was A-OK. Said the play in the tailshaft was normal and that the seal and bushing were fine.
Didn't charge me for anything either
I still can't understand what the problem could be. After raising the rear and looking at it, it seems that the sound is definitely coming from the tranny end of the driveshaft. Now take note that when I watched the driveshaft spin up, I could see that it has pretty bad balance, it rotates about .25" off center. Could the sound be from it rubbing against the oil seal as it wobbles around?
If I can't figure this out I guess I'll just leave it, although it is pretty annoying
Thanks guys,
Alex
Old 05-27-2011, 08:34 AM
j cAT j cAT is offline
Thanks guys,
Alex
if the drive shaft transmission yoke moves up down with the wheels/load off the drive shaft the bushing is worn..\\I have had this occur and repaired ..no big deal ..that yoke should be held quite securely ..you cannot have the drive shaft wobbling by any small amount.
Old 10-16-2011, 02:38 PM
Can't believe I didn't do this test before, but turns out that when driving at speed, if I put the truck in neutral, both the sound and some resistance completely go away. Put it back in drive and the loud sound and the resistance/friction comes right back. Guess this eliminates the driveshaft/yoke. But what does it signal?
Thanks a bunch,
Alex
Old 10-16-2011, 11:16 PM
trannyman52 trannyman52 is offline
with the drivshaft off,,,shaft can be some what loose
Old 10-18-2011, 10:07 PM
I'm sorry if I misunderstood but what I believe you're saying is that in neutral, even a sloppy driveshaft will not make much noise?
Engine noise and vibration jpar1983 Intrigue 10 12-28-2010 07:33 AM
90 GC front end noise Selec-trak benjaminbunny Grand Cherokee | Grand Cherokee SRT8 1 12-20-2009 06:00 AM
Help! 94 2jz 6spd...transmission noise warman724 General 1 11-29-2009 09:21 AM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
Transmission noise ky_infiniti2000 Maintenance 0 10-09-2001 10:48 AM
