Old 12-06-2010, 08:34 PM
7T9Shark 7T9Shark is offline
Re: 96 Blazer overheating and then....
OK, here are the results - After replacing the thermostat (twice, the first replacement wouldn't open all the way) I also removed and inspected the water pump - looks good; I removed the radiator and drained a bunch of crud out of the inlet.
So, will take the radiator in to the shop tomorrow and have them assess whether or not it can be rejuvinated. In 50 years of car ownership I've NEVER had a plugged radiator. That's why I was looking at every other possibility. Another learning expierience.......
Old 12-06-2010, 08:40 PM
OK everyone, here are the results. Today I removed and inspected the water pump - Looks good, bearing is tight and spins freely. I also installed a second thermostat. The replacement I installed last week just wouldn't open all the way like it's supposed to at temp.
Here's the final assessment. The radiator appears to be the culprit. When removing it, I poured a bunch of cruddy swill out of the inlet pipe. Will take it to a shop tomorrow and see if they can boil it out, as it doesn't leak and looks good. I'll see what they say......
Thanks to all for your suggestions.
AJ
Old 12-07-2010, 02:28 AM
viggy58 viggy58 is offline
just do a full coolant system flush. the rad is prob fine, just needs new coolant.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 12-11-2010, 09:37 PM
Spoke to soon. Filled the system, ran it for awhile to purge the air and then let it sit overnight. Next day checked level and all looked fine. Took it out and same thing. It starts out heating up normally on the guage, and then it takes off. When I got back to the garage the heater was blowing cold again, and the upper radiator hose was barely warm. The thermostat housing on the intake manifold was hot.
This is frustrating given the fact that I replaced the thermostat and radiator, as well as checked the water pump on the work bench and it spun freely.
It's beginning to look like I might have an internal blockage within the block or heads.
The oil checks out fine with no "mayonnaise" build up or evidence of coolant migration. I'll probably take it to a shop next week and let them take over.
A major bummer......
Old 12-12-2010, 06:22 AM
534BC 534BC is offline
Here's 2 things to do if you can:
Do a combustion gas test.
Purge vapor out at the 2 bleeders. (can't tell if you've done this)
To me the venture is very difficult to get vapor out of the system (even with the bleeders)
EDIT sorry I thought I was in a chevy venture thread still. (no bleeders yes.)
Old 12-14-2010, 12:36 PM
OK the bottom line is that the THIRD thermostat did the job. Engine warms up and runs at normal temp. now.
Go figure........
98 ranger overheating and passenger side soaked zheath09 Ranger | Courier 3 01-10-2010 12:18 PM
98 S10 blazer runs and then dies Billy J Problem Diagnosis 4 11-22-2008 03:22 PM
2000 Blazer quits and then restarts upon idling when hot PartyMixer Blazer 8 08-19-2006 05:58 PM
Noise and then overheating pianoman78 LS | MKZ 3 03-01-2006 06:56 PM
My blazer turns on and then random shut offs. Beave Blazer 3 06-18-2005 01:24 PM
