Old 08-18-2006, 09:15 PM
PartyMixer PartyMixer is offline
Cool 2000 Blazer quits when stopped and then restarts immediatley.........
...... mechanic had over 24 hours into trying to identify problem and concluded it was fuel pump, which I replaced and 39 hours later... same problem occuring.
It immediately starts again, after shutting off completley with no warning lights. It ONLY stops when engine is running and you're at a complete stop.... at least so far.
HELP
Old 08-19-2006, 01:09 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 2000 Blazer quits and then restarts upon idling when hot
Fuel pump.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-19-2006, 10:38 AM
They replaced the fuel pump.... 24 hours later, same problem occuring.
Old 08-19-2006, 01:59 PM
534BC 534BC is offline
The answer may lie in the 24 hrs spent in diagnosing it. It sounds like it is intermitent and possibly he could not duplcate problem easily. It sounds like electrical, but can you give us some more details as to how long has been acting up, how often it happens. Does it do it when cold? Any other related symptoms or probs? any recent or non- recent repairs?
The one detail you gave (it only does it when stopped) is a great detail, and I would assume that as long as you are driving it and do not stop it would run for hrs?
One thing is for sure, After a few fuel pump replacements one could conclude that it is something else. lol.
Old 08-19-2006, 02:46 PM
BlazerLT's Avatar
AF -Advisor
I would check the ground for the fuel pump to make sure it is connected and clean.
Also check the IAC valve and have it and the hole it inserts into cleaned and scrubbed out.
Old 08-19-2006, 03:09 PM
SO FAR.... it only quits when stopped at a light or stop sign.... it's just begin so not a lot of redundant history to give.... it does seem to surface when hot, but ONCE, it occured after only a few minutes of driving, so technically it wasn't "hot".
Is there any connection to the ignition switch issues that I've read about on other model years????
FRUSTRATED IN GEORGIA.......... aggghh!
Old 08-19-2006, 03:11 PM
The IAC and insert area are good! Thanks....... still can't figure this out!!!!!
Old 08-19-2006, 03:16 PM
I've been wondering the same thing about my "intermittent misfire" If it could be the ignition switch.
Could yours be the egr valve?
Here would be an interesting test, allow it to idle for a long time in netral or park, then let it idle a long time in a gear. How long might it take to stall? maybe never?
Old 08-19-2006, 05:58 PM
BlazerLT's Avatar
AF -Advisor
Did you have them removed and checked?
