| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#16 | ||
Caution: Monkeys bite!
Re: Jeep Grand Cherokee power steering problems
You had a puddle on the ground and an empty reservoir. Before that you were getting foaming and groaning from the PS pump. There have been multiple power steering pump failures, getting closer and closer together in time interval. You've put 2 quarts into the new system - checking online, the capacity is around 1 quart. What this tells me is that there is a leak in your system somewhere, which is getting worse. It could be the power steering box, the hoses going to and from your reservoir, or one of the couplings between those units. The leak is not only letting fluid out, but might also be putting air into the system which may have helped cause the initial pump failure. What I'd do first is wipe down the entire system and get it clean, start it up and turn the wheels all the way L and R, lock to lock. Then examine the system to see where drips/leaks/etc are found. You could also lay under the front of the vehicle (with goggles on) and have someone turn the wheels left and right, lock to lock, and look for any seepage.
Ours: 2020 Jeep Wrangler 2.0, 53k 2013 Toyota FJ Cruiser, 84k Kids: 2005 Honda CRV, 228k |
#17 | |
I have the same problem with my jeep is the same year same make and model I'm curious if you ever figured out what the problem was?
#18 | ||
I still have this Jeep and it's been over 2 years now and the power steering pump is still quite. I don't even know it's there anymore. What it turned out to be was. The first pump was definitely bad and needed replaced. The other pumps failed quickly because of a leak from the high pressure hose where the fitting hooks to the pump. It kept sucking air into the pump. so bleeding it or trying to get the air out was impossible, burning up new pumps. It was tough tracking down the leak and the hose is expensive from everywhere I looked, but was easy to replace. I ended up buying a high pressure hose from rockauto.com for 45 bucks I think. After installing new pump, new high pressure hose, filling with the correct fluid and working out all the air it's been quit ever since. No more power steering problems! I hope this helps you and good luck! |
