hi i have a 1996 jeep grand cherokee its my work car i have over 170000 , miles on it all highway i do like 200 a day however for the past year i have had a loss of power and the engine makes i wining sound i changed the cat at midas it sounds like there might me a exaust leak or some thing sounds like i go cart taking of i need help and i am new to this site and don't know iof i can figure out how to get my responses if you can email me at [email protected] and if your suggestion works ill pay you 200 bucks i am dead serious i am a man of my word please help me
Re: i need help 1996 jeep grand cherokee power loss ill pay 200 to who ever helps me
$200 will definately get you a diagnosis. I own a shop and I charge a flat $98 for diagnosis. That leaves you $102 toward the repair. I'm with glass, take it to a good jeep independant. It's hard to narrow it down on a chat forum without the proper tools. If it were in my shop, I'd check compression, exhaust, vacuum, etc.
Good luck. |
just a thought but try sliding your front roof rack back about 3-5 notiches i've seen that when the air rushes past the roof rack it can make a whooshing sound like your hearing
Keep the shiny side up & the greasey side down and the pedal to the metal. |
If you are inclined to try, check the airways of the t/b intake, and EGR valve. it sounds as though when your cat got clogged, it more than likely caused a great deal of carbon buildup in these areas.
In some extreme cases, you may also need to thouroughly clean your intake manifold to remove the buildup there as well, keeping in mind that some or all of the injectors may need attention. I hope that helps. It's worked for me many times. Especially where clogged cats are involved. Oh, and be sure that your vacuum hoses are in good condition and properly attached. And give your evap system (eec) a good look-over. |
Check your vacume tubing, check your belts. Turn your engine on and open the hood, can hear the whine? Pin point it. Is it from under your car?
ok i want the 200 $ check your tires for inflation press
Re: Re: i need help 1996 jeep grand cherokee power loss ill pay 200 to who ever helps me
