Old 01-12-2015, 06:30 PM
Ronnie Binkley Ronnie Binkley is offline
Re: 2001 Pontiac Grand Am: high idle, high rpm shifting
I replaced my mass air flow sensor on the side of the throttle body and it fixed my high idle problems. takes about 5 min to fix.
Old 01-17-2015, 02:56 AM
corem corem is offline
Send a message via MSN to corem
Originally Posted by jessica naviaux View Post
I have an 02 pontiac grand am v6 3.4 the symptoms are it started high idling and then it progressed to going to over 4000 rpms to get the car to move and then it progresses to get better after about 30 to 45 mins after that time frame it acts like a normal car i do have an 02 sensor going bad PLEASE SOMEONE HELP ME
Have you check trans fluid? The high idling could number of things like vacuum leak or idle air control valve. Have had codes pulled to see what the computer is seeing going on. One good thing to check is throttle body for carbon build up.
1996 grand am high idle 5000+ rpm mixerman32 Grand AM 13 05-14-2011 10:00 PM
2001 Grand Am high idle 1200 Rpm jayjp200 Grand AM 4 08-15-2010 05:27 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
97 z 24 high idle & harsh shifting at high rpm danrootbeer Cavalier Problem Diagnosis 0 11-29-2008 07:10 PM
High Idle Speed/rpms..help new2bmw 3 Series 2 03-18-2004 12:49 PM
Tags
computer , idle , pontiac
