| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#16 | |
SHO No Mo
![]() Join Date: Jun 2004
Re: Taurus Dies Mysteriously
These very rare issues can get very expensive to troubleshhot, especially at dealer labor rates. Did you ever get the CMP replaced? I've never actually replaced one so I cannot tell you where it is in your photos.
-Rod |
#17 | ||
Unplugging it will allow the car to run, in most cases because it will usually place ground on the computer wiring causing shut down. Last edited by kjvw10; 11-04-2010 at 04:58 PM. Reason: forgot something |
#18 | ||
Like shorod said earlier, if the radio cuts off for 1 second after the sudden stall, it's a power electrical problem. Either the ignition switch or a bad contact in the under hood fuse box (but less probable). Because of that, the CMP sensor has nothing to do with that. The bouncy RPM when engine is off is normal on these cars. I forget exactly why, but I remember that the rpm gauge is very sensitive. It can jumps from 0 to 1000 rpm quickly when engine is off. The stumbling problem issue can be totally different from the stalling issue. Taurus is know to have many different issues. Don't try to link them all. This one can be related to weak fuel pump, bad EGR system, vacuum leak, bad PCV... or you repaired by changing the plugs.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar.
#19 | ||
SHO No Mo
-Rod |
#20 | |
You're right, the "play" test is no very relevant. Momentary operation could be normal.
So the ignition switch's contacts should be inspected.
| Tags |
| dies , mysterious , taurus |
