Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 04-26-2004, 11:56 PM
gable74 gable74 is offline
Re: 2003 Yukon Denali Navigation Radio
JeepGuy...you need to upgrade your AMP and make a few wiring changes at the AMP harness. You need a bose "LUXURY" AMP like the ones found in Denali's, Escalades, and Hummers. I have some part numbers posted above. I had the same problem as you, then i got the right AMP and fixed the wires at the harness, and BINGO!
Here is the manual.........
https://www.mygmlink.com/pdf/go2cont...calade_nav.pdf
Old 04-27-2004, 09:19 AM
Vintalage's Avatar
Vintalage Vintalage is offline
Send a message via AIM to Vintalage Send a message via MSN to Vintalage
Anyone have the wiring schematics for the Nav unit?
Old 04-27-2004, 11:44 AM
for which harness? there are 2 on the NAV and one at the AMP.
Old 04-27-2004, 12:06 PM
Vintalage's Avatar
The main harness that provides power to the nav unit.
Old 04-27-2004, 06:20 PM
here ya go
http://files.automotiveforums.com/ga...sort=1&cat=503
Old 04-27-2004, 06:32 PM
Vintalage's Avatar
Thanks! Appreciate it.
Old 04-28-2004, 12:04 AM
pacethis pacethis is offline
Hi all,
Took a lot longer to replace my console than I had planned. The first one I ordered never had the front part shipped, which left me mid project in serious dis-array...
Anyway, I ended up getting a new 04 Escalade console, complete. I've already sold my nav setup in favor of an alpine setup, but have some parts someone here may be interested in. I bought a new console, complete with wiring, amp, mic, 6disc changer, etc. It's never been in a vehicle.
The amp is 15054675. The changer is 15055250. Rear audio controls 15767145. Mic 25705367, and auxillary wiring harness (can't find a part number), but it connects everything in the console (amp, changer, lighter plugs, etc).
I don't check this forum every day, so if you're interested, email me at [email protected]. If I don't get any takers in a few days, I'll probably put it all on eBay. If someone here wants the stuff, I'll sale it all for $600 shipped. Price a few of those parts, and you'll see it's a pretty good deal, especially all in new condition.
Thanks,
Josh
Old 04-30-2004, 09:25 PM
snomien snomien is offline
pacethis - How does your door chime and things like that work with your new Alpine setup? Does everything work as if the stock unit is in it? I have a Colorado with the new data bus setup and would like to install some sort of nav unit. I don't have the Bose sound system.
Old 05-01-2004, 12:12 AM
Re: Re: 2003 Yukon Denali Navigation Radio
You'll need the right adapter. Mine was from Circuit City and like $70 or $80. It does an okay job with door chimes, power retention, etc...but not perfect. Occasionally, the doors don't chime, or chime for several seconds after doors are closed. Power retention sometimes stays, sometimes doesn't, occasionally stays even after truck has been locked. It does work fine 99% of the time though...
Old 05-01-2004, 12:15 AM
Re: Re: Re: 2003 Yukon Denali Navigation Radio
By the way, if you're going to install a nav unit anyway, I'd highly suggest going the factory route. It's going to be a better product for the money. Since you don't have the bose setup, you'd need the new amp, and maybe the speakers (I sold all the speakers from mine, including sub, for around $100). The right amp will cost you $300-400 (I have one available as of now) and you can get the nav hu on eBay for ~1500. Maps, etc will cost you another $200. All in all, it's not a cheap venture, but it is a nice setup.
I just decided I didn't really need nav, so I went with an alpine mp3 deck. Put the money towards a new console and some other things...
Old 05-01-2004, 01:51 PM
bokeefe bokeefe is offline
Re: CD Changer
[quote=jeepguy44]I just put a Nav Unit from an H2 in my 2003 Tahoe. The whole install was very easy. It works fine, but I want to add a GMC cd changer so that I dont have to remove the nav disc. One question:
So you didn't have any problems installing tha nav radio from the factory 6-disc in dash rds radio?
Old 05-04-2004, 09:59 PM
tonytone tonytone is offline
I could be wrong, but doesn't a GM vehicle with the factory-installed OEM nav unit also have wheel sensors (or similar) which help aid vehicle navigation tracking when the nav unit isn't able to pick up a GPS signal while the vehicle is in motion? I mean, the nav won't be able to accurately display your vehicle location onscreen if your vehicle is inside say, a tunnel...not unless it's psychic.
Old 05-05-2004, 05:44 PM
the vehicle (all gm 2003 and up) have a VSS wire (vehicle speed sensor). This wire is connected to the HU harness when the NAV unit is installed. This is what tracks your position when the GPS signal is weak or unavailable (which is almost never). A version of this signal is also what controls your AVC (auto volume control). So when you go faster, your radio gets louder and when you slow down, it turns the volume back down.
Old 05-08-2004, 12:41 PM
Almost never? Ever driven through a dense forest of redwoods? Or in a long tunnel? Not trying to be argumentative, but there are places where the GPS antenna may not be able to pick up a strong enough signal...or any signal at all. Yeah, I know you said "almost"...
Old 05-09-2004, 04:11 PM
jeepguy44 jeepguy44 is offline
Send a message via AIM to jeepguy44
nav
Gable-
I've got the appropriate Bose amp now and my console is pulled apart. What are the changes you made to the harness so that it would work? I'll be trying a few things but any help would be appreciated.
Christopher Dempsey
New transmission in 2003 Yukon Denali AWD juanb25 Yukon 2 04-05-2006 06:21 PM
2003 Yukon Denali Xl rear disc brake removal ftp Yukon 3 11-29-2005 12:16 PM
2005 GMC Yukon Denali Navigation scott Pill Yukon 2 11-15-2005 07:05 PM
2003 Yukon XL Navigation plaparoo Yukon 2 05-12-2005 05:09 PM
2003 yukon denali navigation system clydjesse Yukon 6 09-20-2004 09:26 PM
