Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 08-28-2004, 02:46 PM
clydjesse clydjesse is offline
2003 yukon denali navigation system
I am planning to intall a factory navigation system in my 2003 yukon denali. Do I need a special wiring harness? Is there anything else I need to know before I install the system? Also, I was told that a special controller was needed for the navigtion system to play dvds. If anyone knows anything please let me know. thanks
Old 08-28-2004, 10:25 PM
gable74 gable74 is offline
Re: 2003 yukon denali navigation system
in your Yukon its plug and play...simple and easy. Remove your radio and plug in the NAV. The NAV cannot play DVD movies without some expensive modding.
Old 08-31-2004, 06:23 PM
tonytone tonytone is offline
You'll also need the factory 6-disc external CD changer if you plan on listening to CDs while using the navigation function, assuming you don't already have one (the changer). Plus you may also need to have the nav unit reprogrammed at the dealer...
Old 09-13-2004, 08:09 PM
drno drno is offline
can the nav system be fixed so you can make entries while moving?
Old 09-13-2004, 08:10 PM
I want to be able to use the nav system in my 2003 while moving, but the factory settings won't allow this. can I disable the feature some how? [email protected]
Old 09-14-2004, 11:39 AM
Re: Re: 2003 yukon denali navigation system
Hey if you can figure it out, please let us know! I reckon that there is some sort of programming which locks out some of the controls based on the speed sensor input; if this is stored in NVRAM (I doubt it but you never know), maybe someone can reverse-compile the code and take it out...
Old 09-20-2004, 08:26 PM
you can add a DPST toggle switch to the VSS wire and DATA wire to switch them off, then you should be able to make moving entries. I have never tested it, but these are the only 2 wires that provide speed data to the NAV. Of course it could have the opposite effect and lock you out all of the time..., but in theory it should work.
