Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 10-31-2010, 05:02 PM   #16
BNaylor
BNaylor's Avatar
Re: Wheel Bearings
What torque values to use has been confusing through the years. The procedure at the link was written up with a 1997 factory service manual which specified 151 lb-ft. I think you'll be OK. I used the same procedure when I did the front hubs in my Grand Prix GTP and went with the 151 lb-ft. It hasn't self destructed yet. I used aftermarket BCA-National hubs on that one.
However, for some reason later on GM changed the torque value to 119 lb-ft which is what the 1999 factory service manual states.
So I went with 119 lb-ft on our '99 LS but with AC Delco replacement hubs in early 2009. The Delco hubs came with 3 new hub to spindle bolts with threadlocker applied. I still had to purchase new axle nuts separately.
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 10-31-2010, 05:56 PM   #17
eccs19
Re: Wheel Bearings
Very interesting that it's changed that much over the matter of a couple of years. Maybe to be safe, I'll loosen them up, and change it to 119 or so. Thanks for clarifying. May not be a bad idea to update that other thread to make sure there is no confusion.
eccs19 is offline   Reply With Quote
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
