Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-24-2010, 11:21 AM
eccs19 eccs19 is offline
Wheel Bearings
While my car was dead due to fuel pump problems, I borrowed my Dad's car. His is the exact same car as mine (1999 Regal GS), but with about 125,000 less KM on it than mine. After getting my car back together and taking it for a test drive, I'm convinced my wheel bears are gone, due to the noise while driving in the front end. What's the best way to determine what side needs replacing? (unless of course both are shot)
Thanks
Old 10-24-2010, 11:45 AM
Scrapper Scrapper is offline
AF Premium User
Re: Wheel Bearings
jack it up and see witch side has play but not always shows play just your roar. also look at your outer axle boot see if either one is ripped. if cv joit go's bad it makes a clicking noise when you turn left or right.
Old 10-25-2010, 08:47 PM
stripe stripe is offline
Re: Wheel Bearings
Thanks
I just had to do the same.
Put wheel blocks on both sides of back wheels.
Jack up either side off the ground.
Start car and put it in gear. It need,s another person to listen as you stay in the car.
If it is the bad one you will know.(but check both)
When you change the bad one I really recommend using a torque wrench
(you will get longer life till it goes again)
Cheers
Stripe
Old 10-26-2010, 08:35 PM
Re: Wheel Bearings
I checked both sides of the car, and both sides have play in the wheels. I half expected both may been gone. Bearing are cheap enough, so going to change both sides.
Old 10-27-2010, 09:49 AM
012620's Avatar
012620 012620 is offline
Smile Re: Wheel Bearings
Howdy, how did you check for play in the wheels. Did you check for any movement by grabbing the tire at the top (12oclock) and grabbing the tire by the bottom (6oclock) position. Any movement is more then likely a bad wheel bearing. They are not real hard to change. Just takes time. Good luck.
Buick Park Avenue (Base). I'm still crazy after all of my 75 years. :0)
Old 10-27-2010, 10:39 AM
Re: Wheel Bearings
I checked for play top to bottom & left to right, and got an equal amount of play all directions on both sides of the car. Bearings are cheap enough, so just going to replace them both.
Old 10-27-2010, 11:00 AM
012620's Avatar
Re: Wheel Bearings
It sure sounds like a wheel bearing to me. Before I changed my left front bearing it had only a little play. But after I got it off the car and spun the bearing you could fill the roughness. I think you are right on track with bad wheel bearings.
Old 10-27-2010, 11:09 AM
AF Premium User
Re: Wheel Bearings
i'd just go ahead and replace both of them and have it done and over with. some people on here just don't get it. i might be one of them but i not pure stupid.
Old 10-29-2010, 06:53 PM
Re: Wheel Bearings
Well I got one side done. Took about 2 hours. It would have gone faster, but the hub was stuck. Took about 10 minutes to get it out, then another 10 minutes to get the electronics out. (ABS sensor) It was corroded pretty good. I had to clean the knuckle up to get the new hub in. One thing to note, the top bolt for the hub is a bugger to get to. I don't think I could have easily done this job without air tools.
Test drove the car, and I've not got ABS brakes. First time in a couple of years. Still noisy in the other side, so going to do it tomorrow. Also doing the front brakes as I go, as I also have warped rotors. I'll post an update once I get the other side done. I'm hoping it will come apart easier, but not betting any money on it.
Old 10-30-2010, 01:41 PM
Re: Wheel Bearings
Other side complete. Car is nice and quiet now, and no more pulsing of the front brakes. This side went a little easier & faster than the first side. Would I do front wheel bearings again myself? I would give this one a yes.
Old 10-31-2010, 08:55 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Wheel Bearings
Did you use the air impact tools on the axle nuts? What torque value did you use on the axle nut preload?
Timeslip 08/12/06
AF Community Guidelines
Old 10-31-2010, 11:22 AM
Re: Wheel Bearings
I did use impact on the large axle nut, then torqued to 155 lbs.
Old 10-31-2010, 12:34 PM
BNaylor's Avatar
Re: Wheel Bearings
What brand hubs and is the axle nut torque figure what the hub manufacturer recommended? The GM specificed torque value is 119 lb-ft for front hubs a new axle nut. I used AC Delco replacement hubs on our '99 Regal LS and used the 119 lb-ft figure.
Timeslip 08/12/06
Old 10-31-2010, 02:31 PM
Re: Wheel Bearings
I used Auto Sense hub units. They didn't come with any spec sheets. I used the torque that was called out here....
http://www.automotiveforums.com/vbul...d.php?t=668487
I assume that should be accurate? I didn't replace any of the bolts, just re-used the old ones. (3 hub bolts & 1 large axle nut) Should I undo that nut and adjust the torque?
Old 10-31-2010, 02:42 PM
Re: Wheel Bearings
Just noticed that the box has a note saying to use OEM torque specs. Please reconfirm what I should be using. From your comments, I'm worried that maybe I've made a mistake.
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
