Old 03-30-2004, 08:49 AM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
Re: Safe to change to synthetic
I just wanted to know Desertmike1's reason for saying "Dont do It!!" During the summer months is when I do alot of traveling to Upstate New York, Maine, New Hampshire I encounter alot of steep mountains and with my trailer wanted to make sure I'm running the oil that will best protect my truck when its hot as hell outside and I'm putting miles on my truck. Thanks everyone for your reply's!
-Jimmy
Old 03-30-2004, 01:37 PM
WannaOwnAZ71 WannaOwnAZ71 is offline
Synthetic is best
I use Mobil 1 in my 99 volvo T5. I use 1/4 qt between 7500 mile changes. I used Castrol 100% syntec in my 87 Accord...it went 287000 with minimal oil use between 5k changes.... I stake my life on synthetic.
Old 03-31-2004, 03:59 AM
desertmike1 desertmike1 is offline
Jimmiz71,
sorry I didn't get back sooner, but I just fineshed setting up my new computer (2.8ghz P4 T3 connection) this bad boy halls A*
I'm looking for the oil dip-stick on this thing!
Any how I'll give you a few of my own thoughts about Synthetic oils, based on other threads I've read and people I have spoken with over the years.
Before I get started I would like to say that I have no dout in my mind that non petrolium based oils are good stuff, in fact Synthetic oil is the only approved lubricant used in Turbine powered aircraft flying all over the sky, but keep in mind that the manufacture of these engines spend a ton of money getting them certified.
This is were I draw the line, I'll let chevy be the ginny pig.
I'll make a list of what I have heard and read about the pro's & con's
Pro-
- Exl lubricant.
- Better for extreem cold wheather.
- Better for extreem hot wheather. (oil has a 30deg higher opperating tempurature)
- Good for turbocharged engines, do to the fact it cools and lubricates the turbine bearings.
- Longer oil change intervals?
- Slower oil brake-down.
Con-
- Expensive.
- Small engine oil leaks become bigger
- dry engines begin leaking oil
- oil consumption?
- oil pressure drops app 5psi?
You have 80,000 solid miles on your truck, and it sounds like you take good care of it, do you really want to turn it into a chevy "test bed"
Any how these are my own personal thoughts (two cents worth)
-Mike
Old 03-31-2004, 07:54 AM
Jimmiz71's Avatar
Mike, Thanks for the info, right now my truck consumes no oil between changes and I really have no complaints with what I'm using, The last thing I want is for my motor to start leaking =( Ill probably just stick with the Valvoline High mileage with the Lucas stabilizer Ive been using. Thanks for the advise =)
-Jimmy
Old 03-31-2004, 08:44 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
The chevy I have now is the only truck I've ever had that doesn't burn oil!!!!!!! Man it feels good not to have to check it every day. I know this doesn't have anything to do witht he post, I just had to tell someone. SOrry
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-31-2004, 05:35 PM
Jimmiz71's Avatar
Jayson,,, What kind of oil do you use?? How Many miles on your truck now? I agree with you, My 79' burns oil and it sucks to have to check it all the time, with my z71 (the babied truck) I inspect under the hood every few weeks unless im taking a trip, but it is sweet not to have to worry about it all the time.
-Jimmy
Old 03-31-2004, 06:05 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Jimmiz71, I use Valvoline MaxLife as well (10W 30, with STP Oil Treatment) and I have a 92 Silverado with 115,000 and it doesn't use oil nor leak oil. I love it. And I have also heard that an engine on synthetic oil will leak faster then one with regular.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 04-01-2004, 08:41 AM
jeverett's Avatar
Re: Re: Safe to change to synthetic
-Jimmy
I either use Valvoline 5w-30, or Chevron 5w-30. I use what the factory recommends, even though I've used 10w-30 in all my other rides. I haven't had the slightest problem at all so far, no leaks, no smoke, and it really doesnt knock when you start it up unless its reeeally cold. OH I forgot, I have almost 90K on mine right now. And trust me, they aren't easy miles sometimes.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-01-2004, 09:22 AM
Jimmiz71's Avatar
I lucked out Mine came with a block heater, Up here in New England It gets pretty damn cold.. I just plug it in and its good to go in the morning..
-Jimmy
Old 04-01-2004, 10:12 AM
rositis's Avatar
rositis rositis is offline
Once again I must say DONT use the stabalizer. I have seen test on other web sites and its proven NOT to work. It actually hurts not helps. Todays oils are chemically balanced by people that know alot more about oil then we do. Adding a bottle of addative to it does nothing but mess up that balance that the oil manf. intended. If i can find that web site I will post.
Old 04-01-2004, 11:10 AM
Jimmiz71's Avatar
oh.. i thought you meant dont use the stabilizer with synthetic, which i DIDN'T plan on doing,,, anyways before I started using it my truck ran rougher when cold and after adding it my engine has smoother starts. How does it do damage to my engine? The only reason i add it is to lubricate better when starting cold..
I would be interested in seeing the details on this product.
Thanks Rostis,
-Jimmy
Old 04-01-2004, 06:21 PM
rositis's Avatar
here is the test this guy did. it has alot of good info on his site.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old 09-12-2004, 12:19 PM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
Hello all. This is my first post here. Lots of great info. I was reading some of the posts on oil and noticed 90% of you mention you use Mobil 1 in one form or another. I also notice a negative response to Pensoil. I switched to syntethic about 3 oil changes ago because I've always heard what good syn is and decided to do what I could to help protect my investment. Now, my question is this. Like I said I notived alot of you recommend Moble 1, I have always been a Castrol guy. What are your opinions on Castrol?
Thanks for the input.
Old 09-12-2004, 03:29 PM
silveradoman silveradoman is offline
I also use CAstrol 10W-40, the thing is if I use 20w_50 in the summer am I just hurting the mileage? It is very common to get 100 degree plus heat in the summer everyday over here and everybody I talk to down here says 5w-30 will break down very very easily, what´s your opinion?
Old 09-12-2004, 04:11 PM
jeep_cj4x4's Avatar
I use the Castrol Syntec 10-40. I know alot of the newer vehicles recommend the lower viscosity oils (5w-) but I dont know about the breakdown ratios. I just have always known 10-30 to be the all around weight so thats what I use. I just went from the GTX to Syntec.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
2005 E-150 transient fail-safe no-start joey9940 Club Wagon 1 09-21-2009 10:52 PM
How long before my synthetic oil needs to be changed? imnotnotjoe General Discussion 2 07-07-2009 09:38 AM
how to change tie rods? JohnVT Cirrus 3 04-05-2009 11:32 AM
Oil Changes... synthetic or not jdugan C/K 9 03-13-2005 02:56 AM
Fluids Change, Synthetic? or no? any ideas? sasquatch2550 Ram Pickup | Ram SRT10 1 07-26-2004 03:42 AM
