Old 02-08-2004, 11:32 PM
clem24 clem24 is offline
Simple How-To projector lenses (Fujimi NSX-R)
Here's a quick and very cheap little how-to for making realistic looking projector headlight lenses (which IMO looks better than the sakatsu headlights, which seems too "bright"). I actually thought about this while going to bed... Anyway, you'll need:
- length of round clear sprue (the longer the easier to work with). I used a smoke tinted one to make the lens more noticeable
- sand paper (200 up to 1500 or even higher)
- polishing compound (such as Tamiya)
- cutter (such as Tamiya P-cutter)
1.) If you're working on the NSX-R like I did, you'll have to drill out the existing light
2.) Grind down the diameter of the clear sprue with the 200 grit till it matches your light size, making sure to sand it evenly to preserve the roundness
3.) When the size is about right, smooth it out with the higher grits, eventually finishing with the rubbing compound
4.) Grind the end into a half ball with the 200 grit, and again, work up to the rubbing compound
5.) When you're satified with the look (it should be fairly smooth), cut off about 5mm or less, depending on how deep you drilled (I drilled right through the body, and it'll look better if it's a little longer). Also, I use a p-cutter just incase plastic cutters crack it b/c the clear is very brittle.
6.) Smooth out the cuted end, as above.
You should now have something that looks like a bullet or a suppository. Shove it in the hole and enjoy! Non-tinted clear should still give you that dark look of a projector lens, but I just wanted mine more noticeable. Here are some pics:
This shows the sprue already grinded down and smoothed out to the size of the NSX headlight, and the first completed lense
All 4 headlights drilled out and fitted with the lens
What it *should* look like...
clem..
Old 02-09-2004, 02:32 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
Re: Simple How-To projector lenses (Fujimi NSX-R)
Very good idea! Thanks for sharing.
Pedro
Click the picture to check my progress thread:
Old 02-09-2004, 02:49 PM
blueboost's Avatar
blueboost blueboost is offline
that looks excellent. kunta did something like that using Sakatsu's 'Projector lens. yours looks just as good or better and costs $0
Old 02-09-2004, 04:43 PM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
wow great tutorial
Zach
9006 bulb retrofit for an h3 projector lense 96 accord JaredB24 Exterior | bodykits | Lighting 1 07-01-2006 01:30 PM
How to take out Yellow corner lenses? jbizel Grand Prix 3 02-06-2006 06:45 PM
Projector lenses for 02 golf Big Yellow Monkey Golf 0 04-20-2004 07:46 PM
Fujimi NSX (not type R) notes Jay! Car Modeling 7 09-10-2003 03:04 PM
How to install clear signal lenses?? tendryll Integra 3 06-20-2002 08:19 PM
