Go Back   Automotive Forums .com Car Chat > Jaguar > S-Type
Old 05-14-2012, 03:26 PM   #1
danielsatur
Passenger rear door Open Alarm
2000 S Type Jaguar 4.0 149kmiles
Major Alarm ''Passenger rear door Alarm''
The door/latch on the RR door wouldn't latch.
Need to remove the inner door panel, 1/4 rear window, and exterior door handle for lock latch removal.
Caution - The exterior cover for the door handle has a 8mm screw inside of the door, and the other end is fasten with a clip, it needs to be push in to pop the door handle cover off.
The other 8mm screw can be remove from the out side fora door handle removal.
If the clip breaks, just use a little Home depot liquid nails for easy installation.
New door/latch - $300
Used from a doner Lincoln LS - $20
Modified by grinding steel rivet from linkage on LS lock latch, and switch linkage from bad Jag lock latch to put on LS Lock latch.
danielsatur is offline   Reply With Quote
door open alarm buzzer AutostradaVR4 3000GT/Stealth 4 05-04-2008 02:11 PM
water in passenger rear door PaulD General Discussion 2 05-08-2007 07:32 AM
Rear Door opens itself when in "park" with motor running vanbc Caravan | Voyager 1 01-05-2007 06:11 PM
door open alarm empress Windstar 18 05-25-2006 08:41 PM
1997 wndstar passenger rear door panel removal guide plz mgsolo Windstar 0 07-03-2005 05:50 PM
