Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 05-06-2007, 08:08 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
water in passenger rear door
How does the water normally drain out ? isn't there several little drain holes ? My friends '98 Avalon has what sounds like a gallon or more trapped in the rear door
Old 05-06-2007, 11:27 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: water in passenger rear door
There are holes in the front and rear bottom of the door. Many times leaves or other stuff get into the door and cover the holes. Take a stick, find the holes and poke up through them. You will get wet if you're not careful...
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-08-2007, 06:32 AM
Audio Guy
see, that's wat I thougt .... but there plastic peices in te way. Maybe I will try a coat hanger.
