Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 09-21-2001, 11:16 PM
Koojo's Avatar
Koojo Koojo is offline
Send a message via AIM to Koojo
Can you do this to get more air?
How about taking a soft bendible pipe of some sort, and running it from the tube opening that is behind that right headlight, and down to where the holes are on the bottom of the front bumper? Would this work since air is forced more into the air box when moving? What are the pros and cons of doing this? How about during winter for example, or if something gets inside the tube? Thanx
Old 09-22-2001, 09:25 PM
Koojo's Avatar
no one knows the answer to this question????
Old 09-22-2001, 09:40 PM
pist pist is offline
Send a message via AIM to pist
i was thinking of doing something like that... you would have to have a pretty big tube... my pipe by the headlight isnt gonna be hooked up to my airbox since im gonna have a stillen/k&n type filter... basicly im going to have that pipe blowin air on my filter so if it gets clogged i will still be getting air in just without the forced induction... does that make any sense?
Old 09-22-2001, 10:01 PM
Koojo's Avatar
How about put the tube near the back of the fans, so when the fans spin, it automatically pushed air into the box. You also dont have to worry about shit getting into the box and cloggin it up. Any ideas?
Old 09-22-2001, 10:03 PM
Jay! Jay! is offline
Horizontally Opposed
If the fans are behind the radiator, you'll get a bunch of hot air, won't you? Or will you be getting enough air fast enough that it won't even matter?
Hierarchy of Subaru:
(Click to see mine!)
Old 09-22-2001, 11:06 PM
kenchan's Avatar
kenchan kenchan is offline
ram air huh? humm.... probably worried about water getting onto the filter than anything...
my lude's got a competition intake by iceman. the cone filter is inside the front bumper and getting a lot of cool air from behind the front fender area. the first thing I noticed when I put the comp extention on was more torque off the line and deeper meaner tone all the way up to redline. its a nice system. gonna get a vafc (apexi) for it this week.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 09-23-2001, 12:33 AM
primera man's Avatar
"P-Man"
The fan would be blowing air through the radiator from the back....away from the pipe.......therefore it would be sucking the air away from the pipe.
Plus the air going through the radiator would be hot air.
As for the pipe towards the bottom of the car..???
I think i'd be to worried about all the shit you could pick up off the road.
View All My Models Here.
Old 09-23-2001, 01:47 AM
kris's Avatar
kris kris is offline
Off playing with fire.
On my old civic, I had some piping go down below the front bumper. I had a regular WAI. I built a small box around the cone filter, with there other end of the pipe aimed towards the filter. I will see if I can get some pictures made up. Yes it can be done, and yes, it will be better than what is there now. But no it will probably not give you any gains. No, you really would not be able to get water up there, unless physics have changed.
Old 09-23-2001, 02:30 AM
P10DET's Avatar
P10DET P10DET is offline
Basically, if you run the pipe to an opening in the bumper it might help, but so slight as to be unmeasurable either on the dyno or on the track.
Forget any ideas about ram air. The engine is sucking air so fast that there is no positive pressure there. A lot of people mistakingly think this would be a ram air set-up, but it takes a lot more than that. If you want to put high pressure air into your intake, source it from the base of the windshield. That is a true source of positive pressure as the base of the windshield is a pretty high pressure area.
Forget any ideas about it really affecting the air intake temp worth a hoot - at least not enough to be measurable.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 09-24-2001, 12:56 PM
str8maxn str8maxn is offline
What about trying something like this, the hood scoop. This is what the homies for Japan did? I think this would be the same as running a CAI to the fender. Assuming that you setup an encloser near the filter.
Juan
91 G20 in need of a clutch....
:bandit:
Old 09-24-2001, 01:13 PM
Sm00th G2o Sm00th G2o is offline
Send a message via AIM to Sm00th G2o
The HP gain for air tmp isn't worth tryin to do a custom intake system. I have heard that for every 10° cooler the air goin into ur motor, you get about .5hp. I guess you could gain a few HP off of it... but I wouldn't. And about gettin air into ur motor, you wont have to worry about it unless ur tube gets totally sumurged in water. Think of it like a straw. When their is not much left in ur cup, water goes up the side of the straw to a point, then falls back to the bottom, but if their is enough water it will suck it up.
FU** some N.O.S.
Objects in mirror are getting their asses BEAT!
Another proud member that had a run in w/ the AF curse.
Old 09-26-2001, 03:08 AM
GtRider GtRider is offline
Send a message via AIM to GtRider
Your Basically trying to make a cold air intake!!
by runing a pipe all the way down to the factory air box in the wheel well
you just put the filter at the end of the pipe and hook up the other end to the throttle body
Why you should check the air filter occasionally james_smart Engineering/ Technical 6 12-31-2009 04:06 PM
Getting more air to the Carb grourown420 Ram Pickup | Ram SRT10 0 05-14-2004 11:58 PM
Can you get cold air intake for domestic oldsmobiles? SkYLiNeFrEaK General Discussion 3 01-03-2002 09:02 PM
