Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 08-14-2002, 05:02 PM   #1
OGRED
oil leak help
i had a really bad oil leak last week, i replaced the valve cover gasket, oil pan gasket, and crank shaft gasket. (along with a broken radiator and an oil soaked timeing belt). Now i still have a slight oil leak and my timing belt is getting "wet" again. wtf else could it be? thanks for the help
OGRED is offline   Reply With Quote
Old 08-14-2002, 06:11 PM   #2
Si2000 Vtec
Send a message via AIM to Si2000 Vtec
Everything torqued to specs? Clean the motor really well, go drive the car, and then locate the leak.
Si2000 Vtec is offline   Reply With Quote
Old 08-14-2002, 08:31 PM   #3
OGRED
yea everything should be torqued down a mechanic did it. and i cleaned everything after they were done. The oil drips down on the driver side then i have some on my transmission also. and all the gaskets have silicon in them now as well, so i was thinking it could be the gasket between the transmission and engine. but that wouldnt explain the leak on the driver side would?
Oil Leak in radiator Southern Comfort Camaro Discussions 2 07-26-2009 10:40 AM
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 01:44 AM
oil leak?? Help! hotice318ti S2000 2 06-29-2007 01:49 PM
Oil leak............HELP!! 2xKlutch Off-Topic 0 04-28-2004 03:47 PM
Oil Leak!!Help!! cole92'3.1L Lumina 2 05-25-2003 07:49 PM
