Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-10-2002, 08:42 PM
DRxCIVIC DRxCIVIC is offline
broke a bolt helpp pleeeeeasee
today i installed my springs.. i got done with the front then it was time to work on the back springs... i removed the monunting bolt that is attached to the lower end of the shock absorber to the lower arm... i guess i put too much tension on the mounting bolt and broke it... now a piece of the bolt is stuck inside of the trailing arm.. does ne one have an idea how to take it out beside hammer and chisle it???
Old 08-10-2002, 08:48 PM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
I'm not really pictureing the problem...you might want to get some pics so everyone will know whats going on....
Old 08-11-2002, 12:06 AM
strodda strodda is offline
if youre lucky you can just hammer it out, like you said. although i, along with many others have had a similar problem, the bolt was rusted inside. in which case you wont be able to just knock it out. i dont know what others did, but i just had it welded out and slid a new bolt in.
Old 08-12-2002, 01:40 AM
civ69's Avatar
civ69 civ69 is offline
Send a message via AIM to civ69
ahh yes, the infamous problem with the rear lower shock bolts on honda's. I just did mine on my civic, and I found out the hard way by my car sitting on jack stands for a week, waiting for parts to come in from the dealer, specifically the rear lower control arm bushings 22.00 a a piece, and bolts which were 12.50 each. I dont know exactly what kind of vehicle you have, but on the civics there is a 3/4'' nut welded to the lower shock mount, and then there is a 10/18 bolt that goes through the shock and to that nut. I sat on those 10/18 bolts with an impact for about 5-10 minutes and the damn things wouldnt budge, so i took a 7 foot pipe on a breaker bar and ended up fucking the bushing up cause the bolt was rust welded into the bushing. So eventually i had to cut both bolts with a cut-off tool and grinder, and that let me get the shock out, then i had to take the control arm off to press in new bushing. So the moral to this is, if the bolt is broken off inside the bushing I dont think you will be able to get it out with a hammer and chisel, your best bet is to cut the bolt and bushing sleeve from the insides and get the shok out of the way. Then you will probally have to get new bushings and bolts of course, pop the control arm off and press in new bushings, most garages will press in the bushings for you for little $$..
Good luck and hope this helps..
Old 08-14-2002, 07:13 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
i had the same problem too. i got to the point that i had to cut the bolt and remove the knuckle. i took it to a shop to press the bushing out, and press a new one in. it cost me like $40 plus a new bolt from honda($7.50)
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Broken front seat bolts marlonn Windstar 3 10-15-2010 09:01 AM
Windstar wheel bolt pattern olopezm Windstar 1 08-09-2010 07:31 PM
Broken Stud Bolts cowgirl97cummins Ram Pickup | Ram SRT10 0 05-28-2009 10:37 AM
How to remove broke bolt from aluminum Mayday0017 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 08-18-2004 09:59 PM
broke bolt in the block smokeymicpot '88 - '91 Civic | CRX | Wagon | Shuttlee 10 07-29-2004 10:47 AM
