Old 06-26-2004, 05:22 AM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
broke bolt in the block
ok i was taken my header off and broke a post that the bolt hards on to.
any ideas of how to get the rest out wiht out hurting the hoel or to jsut get the bolt out?
Old 06-26-2004, 11:48 AM
stickershop's Avatar
stickershop stickershop is offline
Re: broke bolt in the block
Is any part of the bolt sticking out above the surface of the block? or did it break off flush with the block? If it's sticking out, you could get someone to weld a nut onto it and then turn it out and replace it.
StickerShop.ca - got stickers?
High Quality Custom Vinyl Graphics, Signs, and Banners :thumbup:
Proud owner of two 1991½ Honda CRX Si Special Edition's (sequential VINs too!)
Old 06-26-2004, 11:57 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
If it's actually broke off at the block or even a little inside, any machine shop or good mechanics shop should be able to pull it out for you.
It's not all that hard with the right tools and would just take a few minutes.
Honda Enthusiast
Old 06-26-2004, 12:12 PM
its a little inside and its the end one on the left well it hurt if i put a header on and drive it to a shop win i put the hole car back together? well it leak to bad?
Old 06-26-2004, 12:37 PM
Killa_CRX's Avatar
When Civics Attack!
it should be fine to make it to a shop... just don't break off any more
Honda Enthusiast
Old 06-26-2004, 09:16 PM
Depending on how easy the access is to the broken bolt, and the tools they have available, they may need you to take just the head into the machine shop. I would ask them first. I've extracted bolts from the aluminum head and block before, but it's definitely not something I would recommend to others. One mistake, and you can screw up your block. Aluminum is much softer than steel.
Old 07-28-2004, 10:55 AM
clams_Jager clams_Jager is offline
Send a message via AIM to clams_Jager
fixing this is a pain but doable.
What you can do is pay to have it fixed or save your self on the labor cost and do it your self.
If youdo it yourself you are going to need to get a bolt remover/extractor kit, sears sells them. it comes with drill bits and these things that look like funny drill bits (the extractors). What you do is pick out the drill bit that is a little smaller in size than the bolt you are removing and drill into the bolt thats in the block, go in about 1-3cm depending on how much is left in the block. then you take the extractor bit and put that in the hole you drilled and turn it with a wrench or vice grips and it should come out, you may have to use some penetrationg oil on it.
Old 07-28-2004, 11:10 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
I recently installed a header onto my car and i clean snapped off a stud. It didnt hurt none and i torqued all other bolts to spec with a new gasket and luckily i didnt have any exhaust leak. i broke the stud middle/bottom.. but if u broke it on a diff location like the corner of the header u might have a leak good luck
Old 07-28-2004, 12:45 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Use a bolt extractor to get it out, its not that hard. I'v done it many times.
Old 07-28-2004, 11:56 PM
civicwithawankel civicwithawankel is offline
I'd like to say use acetylene but that's not too smart when it's the engine head... I've broken so many bolts cleaning/rebuilding my rear suspension and the torch always worked best to get it apart... I broke 2 extractors trying to get out one 10mm bolt (high strength) and I'd reccomend you buy the most heavy duty one that will fit the bolt so you can really torgue it and get out the bolt, then possibly rethread the hole with a tap if the threads are messed up. WD40 and other similar fluids will help a lot, and possibly 'lightly' heating with acetylene and letting it cool might loosen it up if the threads are seized together. I`m sort of a pyro so I`m biased towards the torch but you really should leave that to the very last resort as you can do a lot of damage with it if you don`t know how to use it properly... (still my favorite tool)
anyway good luck
Old 07-29-2004, 10:47 AM
Forunn Daberator
aluminum head- dont torch it.
