Old 03-08-2006, 03:59 AM
356speedster 356speedster is offline
Decal printing - ALPS substitute
I've read a lot of decal printing posts, and most of them ends up with an advice to get an ALPS DIE-SUB (Thermal wax) printer.
But the ALPS printeres are hard to find, expensive and not very reliable, so I am curious to know if anyone have tried to print decals from cheap DIE-SUB photoprinters?
Canon got a range of photoprinters that use DIE-SUB (Canon Selphy 400, 500 and 600 series), and you can get them as cheap as 50$ brand new.
These printers only have 3 colors, wich means you still can't print white, but they put down each color on its own layer and finish of with a glossy clear protective layer.
In theory this would print nice even colors (withoyt the ink-jet dots) wich are sealed and waterproofed right from the printer, but I'd like to know if anyone have tried this before I buy one since I already got a ink-jet photoprinter and dont need two printers for photo-printing.
---356 speedster---
Trying again! - Links to the old wip's (still searching for the old pics): 911 Turbo '88 - Fiat barchetta- Lotus Elan 26R - 928 S4 - 944 turbo - 924 turbo
Old 03-08-2006, 05:29 AM
klutz_100's Avatar
Re: Decal printing - ALPS substitute
Interesting question - I'm also interestd in the answer
Old 03-08-2006, 06:23 AM
wouter1981 wouter1981 is offline
There is an other way. print you're decals with an normal inkjet printer... Go to a copy center with you're decalpaper and ask them if they want to make a colour copy on you're decal paper.. et voila...
Old 03-08-2006, 07:35 AM
yes, but that means getting into the car and drive to the city, It's just so much more convenient to have a printer on the desktop :-)
---356 speedster---
Old 03-08-2006, 09:02 AM
toyota00 toyota00 is offline
Exactly my point also
Old 03-08-2006, 09:21 AM
ZoomZoomMX-5's Avatar
There is no true ALPS substitute. It's the only printer that will print white, silver, gold, chrome foil, and clear. Printing layer by layer so a white layer can be the first, or double them up for maximum opacity. All the others pale by comparison.
My Fotki Album
Old 03-08-2006, 12:29 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I just got a new Epson that uses 'pigment based ink'. Now, I've not printed any decals yet but the paper results indicate that it should be better then what came before.
I think it would be possible to swap white for one of the blacks in one of the high end 7 color printers as well.
SCCA 7, The lost Z
Old 03-08-2006, 05:28 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
The Alps Printers are well worth the price tag, Also If you only use them for Decals, it should last for years as it will not be used for everyday printing.
Kodak do a printer similar to the Alps called the Firstcheck : http://www.kpgraphics.com/firstcheck/ but the price is very very high.
The printing of white is what is important as ZoomZoomMX-5 said.
Steve a.k.a. Hiroboy
Old 03-08-2006, 05:39 PM
That Kodak unit may very well be made using Alps guts. I had heard Alps still sold the technology overseas, no more printers from Alps in the US but doing a bit of searching seems to indicate the Kodak system is by Alps.
My Fotki Album
Old 03-08-2006, 06:13 PM
Murray Kish Murray Kish is offline
Getting Old...
I read a discussion on another forum about using Die-Sub photo printers. End result was that they don't work.
Found the links. Try these two threads for more detail/info.
http://www.arcforums.com/forums/inde...509&hl=dye+sub
http://www.arcforums.com/forums/inde...867&hl=dye+sub
Murray
Old 03-08-2006, 07:23 PM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
Just read about this company on another board. Have not tried it ands don't know if it will even work, but I think it may be an alternative. It says you can do white, color and full metallics. Looks like something that would need to be researched and tried though. http://www.pulsar.gs/DecalPRO/a_Vert..._It_Works.html
Old 03-08-2006, 07:54 PM
scaleracecars scaleracecars is offline
Die sub printers do not work on decal paper. The ink is vaporizes in die sub printing and a special paper is required to absorb the ink gas. Alps printers come in regular impact printers with an add on part to make them a die sub printer which for our use is not required.
Old 03-08-2006, 08:24 PM
mazinkaiser's Avatar
mazinkaiser mazinkaiser is offline
Looks interesting. But I don't quite get how they could do the white and metallic decals...
