Go Back   Automotive Forums .com Car Chat > Volvo > S80
Old 12-22-2003, 11:19 AM   #1
mrcarauto
Question need help with service engine light and srs
Can anyone help me how to reset the service light for a S80 and also on my S80 right hand side dash broad didn't have a SRS light on but on the left hand side of my dash board which stated "SRS- Airbag Service Urgent".....................Please help!!!!!!!!
mrcarauto is offline   Reply With Quote
Old 12-31-2003, 10:57 AM   #2
tubbyskid
Re: need help with service engine light and srs
Turn ignition position 1
Press and hold the odometer reset button
Turn ignition to position 2 (continue to hold odometer reset button)
After the Service Light flashes, release the reset button.
Tip: Do not wait for the light to stop flashing. Release the reset button within 5 seconds from the beginning of flashing. this should reset the service light. you must be in t1 for the reset to work it will not reset in t2 mode. good luck. tubbyskid
tubbyskid is offline   Reply With Quote
Old 03-23-2004, 04:05 PM   #3
bobbydm
Didnt work for me but may for somebody else you can try
bobbydm is offline   Reply With Quote
Old 08-13-2004, 08:20 PM   #4
S80T6
Talking
Just checking out the forum and saw the post for the service engine light. I went to the car and followed your instructions and it worked perfectly. Thanks
S80T6 is offline   Reply With Quote
Old 11-15-2004, 10:15 PM   #5
geekasaurus_rex
Some codes...
http://www.gendan.co.uk/diagnostic/s...html#volvo_s80
Volvo 1998 - S80 Models
* Turn ignition switch to position 1
* Press and hold the odometer reset button
* Turn ignition switch to position 2
* Wait until service light blinks and then release odometer button
Volvo 1999-2000 - S80 Models
* Press and hold "day counter reset button"
* Continue holding day counter for approx. 10 seconds
* After SRL flashes, release day counter button
* Should hear "beep-beep" to confirm command accepted
Not 100% sure what the "day counter reset button" is, but I think that it is the Trip Odometer Reset button (per the manual.)
Work for anyone? Has not (yet!) worked for me... just got a 2000 S80, and very excited about it, save that my wife freaks when she sees the SRS -- URGENT!!! message.
All that I get is a "26" in the left message window, and the URGENT!!! message still shows up, as well as the red LED "airbag problem" light on the right.
Your thoughts?
wwjd? jwrtfm!
geekasaurus_rex is offline   Reply With Quote
Old 02-02-2005, 12:15 AM   #6
rowleymotorcars
Air Bag light
In order to shut off the light SRS Airbag Service Urgent. You must change the battery first. The vehicle has low voltage and it will not deploy in case of an accident. Therefore, you must change the battery first then follow the steps on the post below. That's how I was told by the VOLVO Dealership.
rowleymotorcars is offline   Reply With Quote
Old 04-13-2005, 03:25 PM   #7
viceversa
just like to thank you for this information,have a 2002 s80 t5.followed your instructions and the service light went out,second time lucky as first time held the button down too long,regards and thanks.
viceversa is offline   Reply With Quote
Old 04-24-2005, 08:18 AM   #8
javster
Re: Air Bag light
I to have just got the srs service urget msg, I like 'geekasaurus_rex'. I done the above to reset the service lights and end up with is the number '26' in the left msg area followed by the URGENT msg with the red light airbad icon on the right which stays on all the time.
I replaced the battery and I still get the same problem and i've also tried a few times doing the reset method again but still the msg comes up and light is still on?
Is there something else I need to be doing? and what does that '26' mean?
Any help would be very greatful
javster is offline   Reply With Quote
Old 09-27-2005, 10:58 PM   #9
99S8029
Reset your trip odo before...
On my '99 S80 this procedure would not work unless "T1" was set/rest to "0". I am not sure if this was implied in the post as it says Press and hold "day counter reset button"; However, I have seen some others "frustrated" over this so I though I would mention it for newbies like me
I am sure this is well-known among the guru's here, right
I have verified this - put some miles on it, again it would not reset unless "T1 = 0"
~M
99S8029 is offline   Reply With Quote
Need help with check engine light code 401 jumpytoad Taurus | Taurus Wagon 2 10-31-2005 01:30 PM
flashing "d" light, and then code 43 with service engine light mwenz33 Accord/TSX/Accord Hybrid 5 08-24-2004 01:52 PM
need help with the 60 degree and 90 degree engines. goatnipples2002 Fiero 3 06-10-2004 02:12 PM
Clicking & shaking with service engine light rcotten Montana/Montana SV6 3 11-28-2003 11:19 PM
