Old 10-27-2003, 05:32 PM
jam4484 jam4484 is offline
Send a message via AIM to jam4484
alternator removal...
I know how to take the alternator off, but how to you get it out of the car so I can put the new one in. I got all of the bolts and the belt off, but I don't know how to get it out of the engine bay, there isn't enough room.
1989 Crx Si
-Aem cold air intake
-thermal cat back
-test pipe(makes exhaust sound really bad)
-Skunk2 short shifter and knob
-Hx wheels
-Tenzo front and rear strut bars
-parts waiting to go on- nuespeed header
-waiting to be built-my spare a6 block, with y8 head, 93 valve cover, z6 intake manifold, integra tb....
Old 10-27-2003, 06:11 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Unbolt the bracket that holds the alternator. It's easy to take off and put on. Once the bracket is unbolted, the alternator will come right out.
Flunky
Old 10-27-2003, 07:18 PM
yeah I got the alternator off, I need to know how to get it out of the car. I can't find enough clearance any where to get it out of the car.
1989 Crx Si
-thermal cat back
-Hx wheels
Old 10-27-2003, 07:54 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
well i had to put my car up on ramps, there isn't enough room from the top but there is plenty of room if you jack up the car. it is very simple if you have the car jacked up. if you are trying from the bottom i have no clue what could be giving you problems.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 10-27-2003, 07:59 PM
well i had to put my car up on ramps to change my alternator and had no problems. There isn't enough room to take it out from the top but there is plenty of room if you jack up the car, it is very simple if you have the car jacked up. if you are trying from the bottom i have no clue what could be giving you problems.
Old 10-27-2003, 08:56 PM
Well, my problem is we tried to pull it out both the bottom and the top, but I didn't have enough room either way. My friend who has a 91 crx si said that I would have to take out my master cyl. so if there is anyway easier than that it would really help.
1989 Crx Si
-thermal cat back
-Hx wheels
Old 10-27-2003, 09:25 PM
sorry i couldn't help, now that i think about it i had to do a great deal of twisting around to get out of my 88 civic dx, that car is now totaled and gone, but it eventually came out of the bottom, i just had to turn it in some funny angles.
Old 10-27-2003, 09:52 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: alternator removal...
there is a very easy way to pull it out. take off your driver's side wheel and tire. unscrew some of the splash guards and move them to the side, then you can pull it from the side.
Empty Pockets Racing Member #1
Old 10-27-2003, 11:13 PM
91bluedx 91bluedx is offline
Hold Up
I'm suprised that I have any easier way. I have to replace my alternator mutiple time now and I have become a pro. You uncolt the thing and it drops down unto the bottom of the engine bay. THer should be some metal bracing and such that will hold it there. You can then slide it from the right side of the engine bay to the left side. There is enough clearance if you move some houses around slighty (don't disconnect anything) simply push the houses aside and pull the alternator up and out.
This has worked serioulsy like 10 times now.
Hope it works for you.
Old 10-27-2003, 11:19 PM
I was just replying to apologize about my spelling mistakes in the last thread. I Will thus correct myself. "I've had to replace my alternator about ten times now and I have become a little bit of a pro at removing it."
Sorry about that
Hope my infor helps though
Old 10-27-2003, 11:41 PM
ur2s2pid ur2s2pid is offline
I am not a pro but I do know that if you unbolt the altenator and pullit to the top of the engine bay you can slide it through the back from the right to the left just behind the throttle body and you will have just enough clearence. Then put the new one in from the let to the right. Good luck and let me know what happens.
Old 10-28-2003, 12:59 AM
BullShifter's Avatar
BullShifter BullShifter is offline
You got the alternator off, but did you remove the bracket on the engine?
see the mount bracket? Remove that & the alternator will come out from the bottom w/ some wiggling.
Old 10-28-2003, 05:21 PM
havnfun328 havnfun328 is offline
Hey 91bluedx, ever figure out why you were burning through alternators? I've gone through 4 now in just over a year, and I'm sick of it. I figure it was the cheap crap from O'Reillys, so I got a better one this time. New battery too. But I'm wondering how long this one will last....
Old 10-28-2003, 06:03 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
I will share my storyof how i got my alty out lol yea i couldnt get it out either from top or bottom until i undid the master cylinder and not took it all the way out but just so i could move it to the side and then alty came out
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 10-28-2003, 07:11 PM
GScivic7's Avatar
Re: Re: alternator removal...
OMG...first do this:
Then do this:
You don't have to take the driver's side axle out, or move the master cylinder
Alternator removal issues calgary_89pgtt Probe 1 11-05-2004 11:16 PM
97 Grand Caravan Alternator removal todd_johnson9 Caravan | Voyager 5 10-30-2004 01:03 PM
1994 Alternator removal rlwillis Cherokee 1 01-29-2004 08:17 PM
91 Si Alternator Removal Aiwen '88 - '91 Civic | CRX | Wagon | Shuttlee 9 05-12-2003 09:50 PM
Alternator removal Cervantes Cherokee 0 04-22-2003 09:20 AM
