Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 12-08-2003, 01:05 PM
mazda323 mazda323 is offline
Question Replacing Speedometer Cable ??
The Speedmeter on my 1993 Mazda 323 is bouncing and vibrating in cold wheather. I think the problem is with the speedometer cable. I have Chilton manual but it does not show how to replace the cable. I appreciate if someone can provide me the procedure for replacing the cable.
Thanks.
Old 05-06-2004, 10:59 AM
gdarkblade gdarkblade is offline
Wink Easier than it looks
been there and made mistakes I hope I can prevent for you.
Provided that you have a manual transmission and no cruise.
The cable is in two sections.
One goes from the transmission up to a rubber pipe where there
is a junction. the other goes from there to the speedo.
In my case the cable broke between the trans and junction.
you just roll up the little rubber pipe and you'll find the junction.
Unscrew it and unscrew the cable from the transmission and
pull it out. It may be a little stiff in the transmission but it just
pops out.
1985 Caprice leaks at speedometer cable Jeffesong Caprice 6 08-23-2009 11:55 PM
Speedometer-Cable or No Cable? hink12341234 Problem Diagnosis 2 12-30-2007 12:17 PM
speedometer cable/wire venx Probe 2 05-09-2005 09:58 PM
91 Explorer Speedometer Cable Replacement Fritz The Cat Explorer | Explorer Sport Trac 0 09-04-2004 02:07 PM
speedometer cable replacement tfle Jetta/Vento/Bora 1 07-29-2004 11:26 PM
