Old 04-21-2002, 07:52 PM   #1
BIGANT
Question 1985 accord 1.8l carb. How can I make it faster?
Listen, Fellas I have an old '85 Accord that I trying to fix up, but its a dog. It's a carburated 5 speed, thats runs well. Can anyone help? Is there anything out there. What do I need? BIgger carb, better plugs?
Please help, I see old civics all the time hooked up. It's my turn now. It was a winter car, but now im ready to race it. I also own a killer 7 series.
Thanks,
Ant
BIGANT is offline   Reply With Quote
Old 04-28-2002, 02:39 AM   #2
BlackBeauty92
if you got friends that can help you with labor & stuffs, then go for it...
if not, then it ain't worth it (unless you got lots of cash to throw around)
simple thing:
rebuild your engine & carburator system (clean all those gunks, new fuel, water, & oil pump, belts, check any leaks, & so on)
lighten your flywheel & new clutch
aftermarket header & exhaust cat back (check Pace Setter usually they got some stuffs for older generation cars)
aftermarket plugs, wires, coil ignition & amp or whatever
big thing (AKA expensive):
bigger carburators in 4 barrel type & fuel pump kit (like WEBER, Mikuni, Solex)
fully build engine (internals)
NOS
aftermarket cat & header
aftermarket bushings, clutch & flywheel
or...
Prelude engine (your generation... or even higher like 2L DOHC non-VTEC prelude 89 & below)
suspension stuff:
Eibach Pro Kit (yes, they do have 'em for your car)
Tokico struts
new bushing (aftermarket if possible)
& so on..
hope it helps
BlackBeauty92 is offline   Reply With Quote
Old 04-29-2002, 03:12 AM   #3
A20A1
A20A1's Avatar
Send a message via AIM to A20A1
Weber is the best... Mikuni is japans mock-up of the weber design.
Buy the 32/36 conversion kit if you can find one.
-MIKE
"THE REWARD IS IN THE JOURNEY..."
3geez member since: September 11, 2001
Cardomain
89 Accord
95 Corolla
A20A1 is offline   Reply With Quote
How can make my 86 Bonneville theft-resistant? cyberhun Bonneville 4 12-29-2006 07:56 PM
94 1.8L mirage: how to install an aftermarket tachometer Aeh_Lecks Mirage 1 03-08-2005 04:26 PM
How can you make a Passat faster? Can you? jimbo69ny Passat 2 02-07-2004 02:11 AM
How can i make my CRX faster and faster.. CrXb18c1 Engineering/Technical 21 12-16-2003 10:28 AM
