Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-29-2006, 03:00 PM
cyberhun cyberhun is offline
How can make my 86 Bonneville theft-resistant?
Is there a quick 'n dirty way to temporarily disable an 1986 pontiac Bonneville so it can't be stolen as quickly? I've seen somebody start one without a key once, all it takes is a screwdriver and a willingness to do some damage to the steering column, and maybe 25 seconds (including popping the door lock without smashing the window).
I don't have theft insurance because the deductible is more than I paid for the ol' war-horse --- so if it goes, it's gone for good, and I want to avoid that. I've got "The Club", and I'm sure there are car thieves who are deterred by it, but I'm thinking maybe if I could pop a fuse out, or put a switch on a wire somewhere, it would be an additional layer-of-defense. I know this can easily be defeated but there are lots of thieves who will try to steal a car and if it doesn't go exactly as planned, really quickly, they'll just go look for another car that DOES'NT have a club or a cut-off switch --- it's virtually impossible to make a car theft-proof, but you CAN make it theft-resistant enough so that most thieves will find an easier target. I know about removing the distributor cap, but that's too much of a hassle to undo every time you want to drive somewhere. The situation is complicated by the fact that I have to park it where I can't see it from inside my suite.
Old 12-29-2006, 04:06 PM
maxwedge maxwedge is offline
A990 racer
Re: How can make my 86 Bonneville theft-resistant?
Break into the fuel pump fuse wires and put a hidden toggle somewhere.
Old 12-29-2006, 05:43 PM
auto trainy auto trainy is offline
Question Re: How can make my 86 Bonneville theft-resistant?
years ago I used to break the neutral safety switch but I dont know if thats possible nowadays.
Old 12-29-2006, 06:48 PM
Maxwedge, I'm looking at the owner's maual showing the diagram for the fuse panel, and there's no fuse listed as being for 'fuel pump'. Number 10 fuse is for "ECM", though --- would it hurt anything or somehow cause any kind of undesirable side-effects if I were to pop the number 10 fuse out? That would stop the vehicle from being started, wouldn't it? Number 7 fuse is, "Crank Solenoid" --- that'd disable the starter motor only, correct? How about popping this one?
Old 12-29-2006, 06:56 PM
Auto_Trainee --- "Neutral Safety Switch" --- sounds like a switch that stops the car from being started unless it's in park or neutral (just a guess). I looked in the manual and there's nothing under "Neutral", and nothing under, "Safety ...". How would you use it to act as a disabler?
