Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 01-26-2004, 07:32 AM   #1
youngvr4
STREET RACING GURU
youngvr4's Avatar
3rd gear grind synchro's?
yeah i think my synchro's are dun for. 3rd gear is grinding every time unless i push in the clutch and wait for about 2 seconds and then put it in gear. ? is can i fix? how much? or do i need to get a whole new tranny? and how much
youngvr4 is offline   Reply With Quote
Old 01-26-2004, 01:22 PM   #2
alan92rttt
alan92rttt's Avatar
Re: 3rd gear grind synchro's?
You can replace the syncros. CRS inc. has the parts available(check the FAQ at www.3si.org for information)
3rd is the hardest to do as that gear is in the middle of the set. Check out vr4-stealth.com for a syncro replacment guide.
Alan Michigan 3S
The Toy 1992 Dodge Stealth RT/TT 13.3 @ 102mph
The Daily Driver 1998 3000GT SL
www.3sgto.org - The New home for 3S Enthusiasts
alan92rttt is offline   Reply With Quote
Old 01-27-2004, 05:17 PM   #3
youngvr4
STREET RACING GURU
youngvr4's Avatar
whats the best way to deal with this issue, now its both my 2nd and 3rd gear grinding, i don't know how to work on cars so i have to pay someone, i found a used tranny for $1,700 with 37,000 miles on it
it sucks when all you have is 600 dollars and won't be able to have $1,700 for at least 2 months. rebuild they say is gonna be $2,500.
DAMN!
Old 01-28-2004, 08:07 PM   #4
Eric3KGT
Send a message via AIM to Eric3KGT
I have a prob 2nd and 4th only. How much will it cost to replace?
Eric3KGT is offline   Reply With Quote
Old 01-28-2004, 11:43 PM   #5
alan92rttt
alan92rttt's Avatar
You can find the parts prices in the faq I mentioned above.
Alan Michigan 3S
Old 01-28-2004, 11:45 PM   #6
alan92rttt
alan92rttt's Avatar
DAMN!
check out kormaxtrans.com they sell reconditioned transmissions for $1700.
AS a stop gap are you using a synthetic transmission fluid? If not try one. If you are try BG Syncroshift(I think gm dealers have it) its not cheap but, Its supposed to be good.
Alan Michigan 3S
Old 01-29-2004, 01:11 AM   #7
youngvr4
STREET RACING GURU
youngvr4's Avatar
yeah more and more peple are saying that it might be as simple as the trans fluid, so i'm gonna check that out and see what happens.
other wise it will be 2 months before i can drive my car, dang man and i was just about to buy the super afc2 and the rev speed meter and or light flywheel.
and that kormaxtrans.com isnt working
Old 01-29-2004, 02:45 AM   #8
talskinyguy
Send a message via AIM to talskinyguy
just double clutch when you drive, it will get you by until you can afford to replace it.
talskinyguy is offline   Reply With Quote
Old 01-29-2004, 11:35 AM   #9
YogsVR4
Funding the welfare state
YogsVR4's Avatar
Send a message via AIM to YogsVR4
and on a side note - its good to see Alan here (one of the admins from 3si)
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Resistance Is Futile (If < 1ohm)
YogsVR4 is offline   Reply With Quote
Old 01-29-2004, 06:52 PM   #10
youngvr4
STREET RACING GURU
youngvr4's Avatar
can you explain to me what double clutching is exactly. cause i did what i bleived what double clutching is and it helps not.
Old 05-05-2004, 10:56 PM   #11
swift_r32
swift_r32's Avatar
theres a thread on dbl clutchin
swift_r32 is offline   Reply With Quote
Old 05-05-2004, 11:15 PM   #12
93PearlVR-4
Send a message via AIM to 93PearlVR-4
My 2nd gear synchro has been bad for quite a while now. If you just be gentle and take your time before putting it into gear you'll be fine for a while. the web site is kormextrans.com not kormaxtrans.com by the way
93PearlVR-4 is offline   Reply With Quote
Old 05-06-2004, 12:02 AM   #13
azn3000GTRacer
Re: Re: 3rd gear grind synchro's?
Just skip shift. The easy way not to mess anymore things up. If u keep grinding you can mess up forks and your gear. Those are more expensive than syncros. From second just go to 4th. It's not that bad i had to do it for awhile.
azn3000GTRacer is offline   Reply With Quote
Old 05-06-2004, 09:17 AM   #14
aznnutty
well, i have have a bad 2nd and 5th... and reverse.. it grinds when i put it into gear but how do you know that it's the syncros and what is a syncro?
aznnutty is offline   Reply With Quote
Old 05-06-2004, 03:28 PM   #15
Igovert500
blue + red light magnet
Igovert500's Avatar
aznnutty...Synchros are the most common problem, so if its grinding...its 99% probably the synchros.
Essentially, they are the parts that allow a gear to connect before the teeth of the gear do, it makes shifting smoother and eliminates grinding that would occur when 2 gear wheels come into contact at differing speeds. Basically when your engine is spinning at a different speed then the gear you are shifting into would be.
Read http://auto.howstuffworks.com/transmission.htm
to get a better idea of how it all works together.
youngvr4, double clutching is as follows:
when downshifting you put the most stress on your synchros, say you downshift from 3rd to 2nd, notice how your rpms shoot up. thats because the engine has to spin faster in 2nd gear, due to the difference in gear ratio, as it does in 3rd...at the same speed. So say you are driving 40, engine is probably spinning 1000rpms faster in 2nd then in it would in 3rd to maintain 40mph.
Well, when you go to downshift, lets say 3rd to 2nd. Rather then just engaging the clutch and jamming it into 2nd, double shift:
1. push in clutch and take it out of 2nd
2. release clutch
3. rev gas for a split 2nd, a bit higher in rpms than it would normally spike to
4. let off gas
5. push in clutch and put into 2nd gear.
Essentially, when you raised the rpms, if you did this fast enough, you put it into 2nd as the rpms were lowering to about the same level as they would have jumped to. The engine is now speeding at the right speed, before you put it in gear, so there is less stress on the synchros and you don't have that lurch when you downshift.
With practice you can do this damn fast.
Also, to agree with alan, synchromesh is good stuff, so is redline synthetic. I found synchromesh for aroun 8 dollars a qt at pepboys and 5 dollars a qt at autozone...changing the fluid in the rear, transaxle, and transfer case really makes a noticeable improvement in shifting.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Igovert500 is offline   Reply With Quote
3rd gear grinding prstriker04 Integra 6 08-27-2004 09:52 PM
3rd Gear Grind Osiris_SVT Contour 2 08-06-2004 02:47 PM
My 3rd gear grind, so do yours!!! *Click here* Catfoodv Integra 3 12-31-2003 01:32 PM
3rd gear grind T.C. SOL Engineering/Technical 8 08-09-2003 08:39 PM
3rd Gear Grinding on Upshift baldwonder Integra 14 01-19-2002 12:42 PM
