Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-02-2004, 05:49 PM
Osiris_SVT Osiris_SVT is offline
Unhappy 3rd Gear Grind
On the way to my cottage this weekend my 1999 Contour SVT developed a grind. All of the other gears work fine, but when I go to shift into 3rd I always get a grind preventing me from shifting into that gear. I can only shift into 3rd gear when the revolutions are perfectly matched and by moving slowly, so I've stopped using it in the meanwhile. Is my transmission gone? Is it the synchros? or something else? How much is this going to cost me, and what parts do I need?
Old 08-02-2004, 08:34 PM
Car Pal Car Pal is offline
Re: 3rd Gear Grind
usually it's the syncronizer and blocking rings, with only one gear. but it could be the input shaft too. either way it has to come out.
Old 08-06-2004, 01:47 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
its the syncro. The 3rd gear syncro is the usually the one to go out first on the post 98 cable shift trans. The syncro isnt all that much, only like $80 iirc. However, its the labor thats going to kill you. Upgrade to the revised 2000 syncro and post 2000 shifter forks.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
