Old 08-19-2002, 08:02 PM
supertex supertex is offline
Send a message via AIM to supertex
Angry 93 chevy TBI to TPI swap...have issues
I just put TPI on my 93 chevy truck. My wiring harness guy informed me that it would be best in my case to use my stock computer rather than to swap for the "7730" (90-92 camaro). The reason behind it was that I could keep my 4L60E, rather than having to annie up the cash for a 700R4. I was told that the chip programmer had the proper program to make my computer run the TPI.
Unfortunately, there seem to be issues that accompany this combo. For one, it bucks (off and on) on deceleration. This isn't really too bad on the highway, but in residential areas, it is quite another story. Next, and my guess is that this is related....is the fact that it has a terrible surge at idle and low speed. I cant do 40 mph without contending with a nerve-racking, relentless surge that bounces between 500-1200 rpm, at about a 1 second hi-to-low oscilation. It is simply undriveable "in-town".
I originally put #30 injectors in the TPI (and the stock Z-28/Trans Am fuel pump), because I was told that they would run fine as long as the chip programmer was aware of the change, and also because I was advised that they would easily handle any future mods that I might make. Now I get told one place that the injectors are the root of my evil, yet the programmer tells me the aren't.
The only other mods that I have made was the insertion of the ZZ4 cam in place of the stocker, and L98 iron heads with 2.05 undercut valves. Originally I had used the SLP 51010, which I was advised was way too big. I was told that the ZZ4 was the best choice of shaft for TPI. I am really disappointed in the power that the machine makes. I don't really think that it runs as good as a stock 92 Z-28 or Trans Am. And I think with the cam and heads it should run at least that good. I wasn't anticipating a top-end screamer, but definitely a tire-fryer. It has neither.
I have to find answers for this. I replaced the distributor, and bought #21 injectors. I have yet to put the injectors in place because of the mixed signals I am getting reguarding their impact on the truck's condition. I have adjusted the IAC and TPS until I am blue in the face. Has ANYONE ever done this, heard of a problem like this, or know anyone who has? Is there a better forum to place this in?
I sure could use some expertise on this.
Old 04-19-2004, 02:00 PM
Vortec350S10 Vortec350S10 is offline
Re: 93 chevy TBI to TPI swap...have issues
I'm guessin it's something with your wiring harness, ECM, and sensors. DO you have all the sensors from a TPI engine? MAP, O2, TPS, coolant sensor, MAF, etc. I have sort of a similar problem swapping from a 4.3 TBI to a 350 TBI- using the 4.3 wiring harness.
Old 04-24-2004, 05:48 PM
blackjack21x blackjack21x is offline
check out www.jimsperformance.com my brother had him build a wiring harness for this same type of setup for a jeep cj7. It was absolutely flawless.
TBI to TPI swap, now running rich huebnm23 F-Body Problem Diagnosis 1 01-24-2011 09:33 AM
93 truck TBI to TPI swap...have issues supertex C/K 3 08-06-2005 04:33 PM
Tbi - Tpi Swap MikeAP Engineering/ Technical 0 06-11-2005 03:54 PM
TPI swap from TBI Geerhead General Discussion 4 11-03-2004 12:16 AM
93 truck TBI to TPI swap...have issues supertex Camaro Discussions 0 08-19-2002 08:04 PM
