Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-22-2011, 07:01 PM
huebnm23 huebnm23 is offline
TBI to TPI swap, now running rich
A few years ago I swapped out my 305 throttle body injection from my 1991 camaro for a tuned port injection from a 1987. I also got rid of the 305 and upgraded to a 350 ci. I bought a painless wiring harness for all of the new sensors, I replaced the fuel pump for the proper one, I replaced the no-working fuel injectors with 24lbs ones. Ever since I finished the swap it has run extremely rich. I followed all of the steps in the painless wiring manual and am out of ideas, I've replaced almost every sensor. Any help would be great, thanks.
Old 01-24-2011, 08:33 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: TBI to TPI swap, now running rich
Coolant temo sensor is usually the first cuplret in a rich condition. However, if memory serves, the largest injector you can run without having to tweak the ECM Ithought was 22 lbs?
head gaskets installed now runs rich and stalls supercamaro Montana/Montana SV6 1 05-23-2009 10:42 PM
Did a rebuild on my 1.0L now runs rich. W00dy Metro 5 08-26-2008 10:27 PM
89 Blazer Wouldn't Start Now Running Rich Markgc Blazer 82 05-13-2006 08:16 PM
Tbi - Tpi Swap MikeAP Engineering/ Technical 0 06-11-2005 02:54 PM
Started her up, and she is now running rich Rooikat Off-Topic 1 07-08-2004 08:29 PM
