Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-07-2004, 10:13 PM
sylsmom1999 sylsmom1999 is offline
Question 93 driver door panel removal
The Driver window is off track. Can anyone tell me how to remove the door panel so that I may put it back on track?
Old 03-08-2004, 04:26 PM
2001 SanteFe 2001 SanteFe is offline
Are you sure it is off the track, the cable may have snapped which causes the window to fall down which is common in this year. If that is the case you can by replacement window regulators for $75 which is what I had to do.
Old 03-13-2004, 05:03 AM
Re: 93 driver door panel removal
I am not sure. My main problem is getting the panel off.
Old 03-13-2004, 09:05 AM
Camry93 Camry93 is offline
To remove the door panel remove all the caps/ plugs hiding the screws and the door handle trim, (there is a screw behind the door reflector light also). After all the screws are removed pry all around the bottom to release the plastic chrismas tree plugs, a flat pry bar works well. Once they are all free push up the door panel to release as it hooks over the top of the inner door skin. Unplug electical connectors and voila its off.
Old 03-13-2004, 02:21 PM
stellar_x stellar_x is offline
I have an issue like this. My door handle broke and I ordered a replacement. Got the side of the door off but I cannot reach the
door handle screws or take off the bar that attaches to it. Anyone know a better way to change it?
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
1990 Driver Door Panel Removal - Help? Ron AKA Caprice 0 05-16-2006 01:37 PM
'94 Cougar inside drivers door panel removal four paws Cougar 7 01-25-2006 08:19 PM
1991 LeSabre Driver Door Panel Removal HeadlessHorseman LeSabre 5 01-07-2006 06:44 PM
92 Lumina Euro Driver Door Panel Removal maui4me Lumina 1 12-07-2005 08:57 AM
