Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 10-05-2005, 01:54 PM
four paws four paws is offline
'94 Cougar inside drivers door panel removal
How do I remove the inside drivers door panel on my '94 Cougar?
Old 10-05-2005, 06:13 PM
red91sit red91sit is offline
Send a message via MSN to red91sit
Re: '94 Cougar inside drivers door panel removal
First remove all the screws you can find, (there arne't htat many) than you look for more ha ha. then you simply pull up on the door, be careful there are a lot of easily broken plastic tabs on the back of it, the trick is pushing up more, pulling out less, installation is a bit tricky, but you'll understand when you got the door out.
Good Luck
Old 10-07-2005, 09:47 PM
Re: Re: '94 Cougar inside drivers door panel removal
Good Luck
Appreciate the response. As soon as I get up enough nerve and patience - I'll attack slowly.
Old 10-09-2005, 07:12 PM
It' really doesn't take very long to do. BTW the arm rest has to come off first. I'm pretty sure there are screws underneath that and a wiring connector that have to get removed.
Old 10-10-2005, 09:09 PM
Thank you. I appreciate your help and unless Murphy and his law jumps in, I'm planning on tackling the door this weekend.
Old 10-10-2005, 10:18 PM
Honestly a door panel removal is a really simple easy procedure. I"m sure you'll have no problems with it at all. "knocks on wood"
Old 01-25-2006, 02:46 PM
KaeJR KaeJR is offline
ok this is more a question than a response. I have a 92 cougar and I am wondering if I can replace the door panels with another years. I know that there are wiring differences but Im willling to tackle that. Will i need to stay with 92 panels or can I upgrade to like a 95 or so that has a different layout?
Old 01-25-2006, 08:19 PM
I'm unfamiliar with those years. However, my first thought is will a '95 fit. I believe there might be a diff. in the interior panel size. Good Luck.
