Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 12-29-2001, 10:02 PM
Quetzolcotl's Avatar
Quetzolcotl Quetzolcotl is offline
Exclamation Anyone Please Help me with chip install
i just got a performancec chip to put into my ecu. the chip i got has 14 pair of wire legs and i got another one with it that is just like it but its just the legs and a frame that you can plug the other one into. my ecu has chips the same dimentions as the ones i got but they all have 22 legs. wtf???
Old 12-30-2001, 12:02 AM
update
ok. in the bottom right hand corner of the ecu (wire harnes on the left side) there is a blank spot where the chip will fit but there is not an installed chip in its place. it is numbered 27256. would i then just unsodder the closed holes and plug the chip in there?
Old 12-30-2001, 12:59 AM
ok. i got detailed instructions from a guy off ebay. the chip goes in the empty slot and you have to take out another one, then add a jumber and a resistor in another place. thanks for looking. if anybody needs the instructions in the future hit me up.
Old 01-05-2002, 06:11 AM
sindogg sindogg is offline
You said thanks and nobody from here helped you. So your welcome
Old 01-06-2002, 02:40 AM
JasonAccord98LX's Avatar
JasonAccord98LX JasonAccord98LX is offline
Send a message via AIM to JasonAccord98LX
and the point of that post was what sindogg???
-Original PH Member-
Registered in May of 2001
'98 Honda Accord Sedan 2.3L VTEC 4cyl 5-speed
Generic Cold Air Intake
205/60/15 Bridgestone Potenza RE950's
Save the Oompa-Loompas.....a site I helped create
http://www.oompa-loompas.net
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 11:04 PM
PLEASE HELP with Stereo Installation tec_41 Sierra 8 01-14-2006 12:33 PM
Please Help with 91 crx ecu chip upgrade questions crxichael Introductions 0 09-20-2005 08:17 PM
Please help with battery installation? mrtwo Corolla/Matrix/Voltz 2 08-11-2005 01:03 PM
Anyone Please Help me with chip install Quetzolcotl Engineering/ Technical 3 12-31-2001 04:19 AM
