Old 01-29-2004, 03:34 PM   #1
eschapiro
95 blazer, OBD-II scantools not reading
This is the #^@#@%@ CPI engine. Nice HP, but that's it.
It is supposed to be OBD-II compliant, but have wasted money on two different scantools (Stinger and a PC-interface), and neither can read codes (stinger can erase codes).
GM dealer COULD READ IT, so my onboard interface is working.
HINTS? IDEAS?
Thanks.
Dave.-
eschapiro is offline   Reply With Quote
Old 01-30-2004, 07:31 AM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
Re: 95 blazer, OBD-II scantools not reading
95 was the "BASTARD" year during the switch to OBD2 diagnostics...Your vehicle is equipped with the 16 pin OBD2 DLC, but the computer and operating system is still OBD1
You can sometimes "trick" the code readers into reading by changing the year to 96...
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 01-30-2004, 08:23 AM   #3
comp
good save that could have been a postal shooting
hadn't got that info, is it- all, most, some,,, 95's
comp is offline   Reply With Quote
Old 02-01-2004, 08:35 AM   #4
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Yes and no.... Early 95 s10 blazers used ODBI.5, later year 95's used ODBII... The best way to tell is to look at the ECM/PCM. If it's under the hood, it's ODBII, if it's under the dash it's ODBI.5. Also ODBI.5 use a top post mounted distributor system, while ODBII uses the side post mounted distributor. The ODBI.5 uses the ODBII connector unfortunatly, so what you need is the adapter that allows a ODBI scanner to be used with an ODBII plug...
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
rlith is offline   Reply With Quote
HELP on some OBD II Codes royto Stratus 2 08-09-2009 08:14 AM
OBD II port not working bluebuick91 Galant 3 09-30-2008 07:09 PM
Any ways to read OBD II code without a reader? aznmarvin Camry/Camry Hybrid/Vista 4 06-01-2004 11:43 PM
OBD II reading for Emissions problem bay 1 ??? MGoBlue102 Blazer 4 03-08-2004 04:05 PM
95 blazer, OBD-II scantools not reading eschapiro S-10 5 02-22-2004 03:54 AM
