Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-12-2012, 02:17 PM
van kleef van kleef is offline
1999 headgasket job done...now problem!!!HELP
Last week I have replaced my headgasget's and all gaskets you can think off with Felpro ones.
Now I have a problem..
At first
-during the replacement I cleaned everything and used all the torque specifications needed for the differend parts....so the job went great...I'm sure off that.
When the job was done I started the engine...first time a direct start and the engine run smooth!!!!
After the warm up the problem came....
Facts:
When the engine is at operate temperature the idling RPM's are bouncing from 700 and 1100 RPM (the engine has an gremlin in it who is operating the gas pedal...............)
After a while the engine stops running....it just shuts off. Everytime when I start it after the stop/stall it start perfect!
I haven driven for 10 minutes and when I loosen the gaspedal for example an traffic light it dies/stalls.....
What I have done now to locate the problem:
-Spray averything while running with brakecleaner to locate an vacuum leak, no difference.
-Put off some sensors to check if there is a difference in idling (no change)
-the temperature sensor gives a little change even as the MAF sensor
- Put off the battery to reset the computer
Also I wanna say that before the big job there was no problem like this...!!!!
-the spark cables are new
-new sparks
-new thermostat
Can you give me a tip???? I'm a little tired from this car.........
greets from amsterdam, Holland
Jorg
Old 04-12-2012, 05:34 PM
FishFind FishFind is offline
One Hot Shot
Re: 1999 headgasket job done...now problem!!!HELP
Make sure you plugged the MAF mass air flow, IAC idle air control, and TPS throttle position sensor. all back in. Also that you connected any ground wires back to the firewall.
Old 04-13-2012, 03:10 AM
sverker sverker is offline
When I had somewhat similar problems I suspected the EGR valve. A bottle of STP system cleaner (or whatever the name was) in the gasoline, then a long drive in one run solved that problem.
Sent from my GT-N7000 using Tapatalk 2
Old 04-14-2012, 07:15 AM
Hi there,
Problem solved!!!
IAC was dirty.Forgotten to clean during the big job.....runs great now!!!!
Bey
Old 04-19-2012, 05:51 PM
One Hot Shot
Good to hear
Old 06-17-2012, 11:33 AM
GuttaFixIt GuttaFixIt is offline
Glad you got it done and running great!! GREAT JOB!! Mine still runs perfect.
Dan
Old 06-17-2012, 11:44 AM
danielsatur danielsatur is offline
Good Job, try a smoke test instead of brake cleaner for checking vacuum leaks, most cleaners are too harsh for new vacuum hoses and gaskets.
97 ram 1500 sport 4x4 tranny problems HELP ME! tabes Ram Pickup | Ram SRT10 3 03-14-2009 08:56 AM
1999 grand prix se transaxle problem Help greghouston Grand Prix 3 11-20-2006 08:41 PM
1999 For Ranger Auto Trans Problems Help Tom123 Ranger | Courier 2 11-18-2005 04:37 PM
Tuned Up - Now Problems - HELP!!! jrwpmw Engineering/ Technical 2 12-31-2003 07:54 AM
