Old 12-30-2003, 08:46 PM
jrwpmw jrwpmw is offline
Tuned Up - Now Problems - HELP!!!
1998 Dodge Ram 1500, 5.2L, 60,000 miles
I just put plugs, wires, cap and rotor on my truck.
It starts and idles fine, but hesitates when driving - almost like it's missing a little. It ran fine before I did this tune up.
I've check the wires to make sure their seated right, I've double checked the firing order, etc.
HELP - this is drivng me nuts! Any idea what the problem can be?
Old 12-30-2003, 09:34 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: Tuned Up - Now Problems - HELP!!!
triple check the firing order & confirm that the plug wires are going to the right cylinders. Make sure that the cap & rotor are on securely. It wouldn't hurt to check the ignition timing if you can scrounge up a timing light and a specification. other than that, make sure you didn't knock any vacuum lines or wires loose while you were mucking about under the hood. If that doesn't cover it, double-check the plug gap.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 12-31-2003, 07:54 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
that about covers it.
Timing, gap, firing order.
it's possible you got the wrong plugs. either too cold or too hot, which could cause a problem.
Mustangs are nice, but I'd rather have one of these...
