it,s back=- p-0440
a week ago it appeared right after i picked up the car from the tranny shop.
a friend erased it. now today it,s back. anyone ever had luck figuring p-0440? gas cap and many other parts involved.i,m thinking maybe a vacuum hose got broken when tranny was rebuilt. what happens if you give up and don,t ever fix it? |
#2 |
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: it,s back=- p-0440
Go back to the tranny shop and have them do a visual of the lines and connections and harnessess of the EVAP system.....
But did you check your cap, and the mating surface of the fill pipe? |
jeffcoslacker,s post about the line to the purge solenoid valve solved my code p-0440.
1st i brought the car back to the tranny shop. no help there. when i read jeffco,s post i got curious and grabbed the line above the brake fluid resevoir. sure enough it was not conected to anything. just by feeling around i found the connection spot and now all is well and the "ses" light went out by it,s self. |
Although I didn't read the code, I had a similar problem after doing my LIM gasket....I failed to plug that line back into the valve and had the CEL lit and a strange sound from the firewall side at idle.
