Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 02-07-2012, 06:55 PM   #1
soskie
Angry Power window problems
This morning it was below freezing and when i went to put my window down the button was stiff but i forced it down and heard a cracking sound.
Now i can only roll the driver window down. Also i can only roll down the passenger window down with the switch on the driver side.
The driver side switch that goes to the driver side window no longer clicks when pressed up but does when pressed down. All the other buttons click so im thinking i broke something within the switch but im not certain.
I also would like to know how to put the window up. I took the door panel off and tried pushing up on the windows but it wouldn't budge.
Any idea of whats going on?
edit: i have very limited experience with car electronics
soskie is offline   Reply With Quote
Old 02-07-2012, 07:57 PM   #2
P_A_B
P_A_B's Avatar
Re: Power window problems
Do you have a DMM? With that you could find out whether the switch is broken or not.
P_A_B is offline   Reply With Quote
Old 02-07-2012, 09:24 PM   #3
soskie
yes i have one.
Old 02-07-2012, 09:44 PM   #4
P_A_B
P_A_B's Avatar
you could check the feed side as well as the ground, and than check across the switch. if none of those are bad, it is probably the switch. Or you could simply use a wire with a fuse and jump the switch. It is usually fairly easy to take the switch off.
The Following User Says Thank You to P_A_B For This Useful Post:
soskie (02-08-2012)
Old 02-08-2012, 07:54 AM   #5
Tech II
If you have the door panel off, easy to check the switch...... disconnect the harness from the motor and attach a test light to the harness.....press switch down....it should light......press switch up....it should light.....if it doesn't light in both directions, bad switch.....
Easy to get window up.....with harness disconnected, get two jumper wires......connect the wires between the motor and harness, the opposite way they would normally go(in other words, have them come out of the harness and switch them going into the motor)...then press down and the window will go up....
The Following User Says Thank You to Tech II For This Useful Post:
soskie (02-08-2012)
Old 02-08-2012, 02:25 PM   #6
soskie
I got it to go up, no more bone chilling drives to work. Thanks!
Power window intermittently inoperable litijus Nissan 350Z/370Z | Infiniti G35/G37 Coupe 0 07-12-2010 04:03 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 02:44 PM
Power windows all quit working. sclbjeep Grand Cherokee | Grand Cherokee SRT8 4 03-06-2010 01:08 AM
2002 mountaineer rear power windows and wiper stops working juaniro Mountaineer 4 02-12-2010 08:22 AM
Lock, and power seat problems!!!! Jefferscene Taurus | Taurus Wagon 12 01-20-2010 03:00 PM
