Old 02-01-2012, 07:45 PM   #1
burner415
Tps ?
I have a 2000 rodeo, 3.2 V6. It has a 1220 code saying the throttle position sensor is bad. I have sense replaced it with a new one but the code still exist. I have reset the computor by disconnecting the battery a couple times, but upon start re-start the engine light comes back on.. same code.. advise?
burner415 is offline   Reply With Quote
Old 02-01-2012, 08:19 PM   #2
00rodeodave
Re: Tps ?
I have found with my 2000 that I have to use a code reader to wipe the codes. It takes several days just disconnecting the battery.
Dave
2000 rodeo ls ,3 ind. off road lift, 31" geo-landers
rancho 9000/s
72' 1200 hd custom (money pit!)
03' suzuki aerio sx
07' suzuki sx4 awd ( best bang for the buck )
00rodeodave is offline   Reply With Quote
Old 02-05-2012, 11:58 PM   #3
Cat Fuzz
Re: Tps ?
P1220 does not mean that the TPS is bad. It means that there is a fault in the TPS circuit. This could be a problem with the TPS or any of it's associated wiring. Just because a code description mentions a part doesn't mean to replace that part.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Cat Fuzz is offline   Reply With Quote
Old 02-11-2012, 03:00 PM   #4
burner415
Re: Tps ?
On further investigation, it come up as air/fuel metering error.. and it came up with a pending code that the engine temp is below normal specs
Old 02-11-2012, 03:15 PM   #5
DeltaP
Re: Tps ?
Autozone sells more parts this way. Thats why they'll check it for free in the parking lot. Most people will take the chance that the mentioned part is the problem only to find out at home its not.
I'd put my own scanner on it and pay close attention to the snap shot data. Particularly comparing the dash temp reading with the ECM reading. Possible the ECT has shifted or the circuit is shorted.
DeltaP is offline   Reply With Quote
TPS adjustment oddity caffeineaholic Caprice 15 03-13-2011 10:41 AM
Impossible TPS problem entrepa Sidekick 0 10-25-2010 08:25 PM
Testing my TPS jmunny Durango 1 12-22-2009 11:57 PM
setting tps tps problem atv087 Eighty Eight 9 02-14-2006 08:55 PM
TPS, TPS, more TPS. 4GZChatch '88 - '91 Civic | CRX | Wagon | Shuttlee 11 07-18-2002 09:45 PM
