Old 07-15-2002, 12:08 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
TPS, TPS, more TPS.
I can't seem to get away from this tps problem. I got my new ZC in, but I can't come up with a TPS sensor that works right. Can anyone help me out? Does anyone have one lying around? Please help!! :help:
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 07-15-2002, 02:20 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I have the same problem. Just go to a junkyard and get it from there. I'm not sure how to take it out though. A friend of mine used the drill bit to push the screws out . I guess u can do it that way but becareful though.
Old 07-15-2002, 02:28 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I heard you can use anyone but sometimes you have to switch the wires around. I know you can use a DX TPS on a Si if you switch the wires or something.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-15-2002, 08:41 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
The DX TPS will NOT work on an Si. The DX TPS turns the opposite way of the Si. You only need to switch the 2 wires if you are using a DX wiring harness on a Si intake manifold.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 07-15-2002, 08:46 PM
Re: TPS, TPS, more TPS.
Maybe your TPS sensors are not working right because they are not installed correctly, you need to make sure they are set at the right voltage .5 volts closed throttle and 4.5 volts at WOT. The TPS has a little freeplay on the bolt holes so you can rotate it a small amount, just set it til it reads .5 volts closed and 4.5 WOT and it should not throw a code anymore.
-2000 Civic Hatch
-1998 Lexus SC300
Old 07-15-2002, 10:52 PM
4GZChatch's Avatar
TPS Problems
Actually, It is finding one that is not off a DX motor. I can't seem to find one anywhere. Will the ones off the later civics work? I heard that they will. I actually had a DX one on my first ZC, but I don't know why it worked. I am a little confused about it right now. All I know is that I can't seem to find one that turns the right way. Please let me know if anyone out there has a spare to spare. Thanks in advance!!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 07-15-2002, 11:57 PM
Yes, the ones off of later civics will work fine, The TPS sensor thats on my car is off a 96-00 civic DX.
-2000 Civic Hatch
-1998 Lexus SC300
Old 07-16-2002, 09:51 AM
4GZChatch's Avatar
TPS
Which wire do you test the TPS from?? Mine has three, red, green, and yellow. I am using a DX wiring harness on mine, how do I know if the wires are the right way around?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 07-17-2002, 09:54 AM
4GZChatch's Avatar
OK, so I got a new TPS, and it ran fine for a day. Then, I hop in it this morning and it immediately threw a TPS code. Any ideas? I know that it has some range of motion, but I don't know how to test it for the right voltage closed. Any help I can get would be great. :help:
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 07-18-2002, 02:14 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
I think that the ZC TPS is backwards from the Si's.
Why does this forum suck so much, I can't post topics because it says I'm not logged in, then when I log in that there is no forum specified then it looses my post. Fuck!
-Dustin
Old 07-18-2002, 08:43 PM
Ok you have a ZC with a DX wiring harness...do this...Swap the two outer wires on the TPS sensor. I bet you that you wont throw any codes after you do that.
-2000 Civic Hatch
-1998 Lexus SC300
Old 07-18-2002, 08:45 PM
oh yea, don't forget to reset the ECu!
-2000 Civic Hatch
-1998 Lexus SC300
