Go Back   Automotive Forums .com Car Chat > Cars in General
Old 10-17-2011, 06:03 PM   #1
Ryan Van Tress
Buying a car for engine rebuild
Hello, I'm new to this forum. I'm thinking of buying a used car sometime that has a particularly simple and reliable engine to rebuild. I have never rebuilt an engine before, so I want to start out with something that is simple, and I don't want to rebuild an engine that is known for blowing gaskets. I would prefer something larger than a 4 cylinder, and the car would probably be somewhat old, early or mid 90s, maybe even older, because I want to get something cheap. Any suggestions?
Thanks,
Ryan Van Tress
Ryan Van Tress is offline   Reply With Quote
Old 10-18-2011, 08:03 AM   #2
Chris V
The Big Meaney
Chris V's Avatar
Re: Buying a car for engine rebuild
If you dont' want to rebuild a 4 cyl (which is really your best bet these days) then you might want to look into older RWD V8 domestic cars or trucks. Parts are inexpensive and readily available. Good choices are Fox era musangs and 4th generation camaros. But, also look at off models, too, like RWD Buicks and Oldsmobiles, or the larger Chevy's and Fords. Or even go with a full size shot whelbase pickup, like the Chevys from the '80s. EASY to work on and get parts for.
That's what we did with my stepson. His first "car" was a truck. A '79 Chevy stepside.
Started with this:
And rebuilt it:
And ended up with this:
The 350 V8 was easy to work on and upgrade.
I've owned over a hundred cars in the last 40 years. What was I thinking?
2013 MINI JCW Roadster
2023 Chevy Bolt
Chris V is offline   Reply With Quote
Old 10-20-2011, 05:52 AM   #3
DerekWhite
Buy used car is best option because you can get used car in cheap price .In usa FL,GA Plam beach there are many used car dealer that they will provide you a car and hope so they can help to rebuild the engine
[link removed by moderator]
DerekWhite is offline   Reply With Quote
Old 10-20-2011, 03:42 PM   #4
Moppie
Master Connector
Moppie's Avatar
That is a tidy rebuild Chris!
I bet loves it
That is some good advice.
Look for something with analogue ignition (points, cap, rotor) and carbs, from the 70s or early 80s.
That will give you a nice simple platform to learn the basics from.
Something that is well supported by a Haynes or similar manual also helps, as is something with a common engine (e.g. small block chev, ford straight 6 etc).
Then you can get lots of help here on the forums during your journey (and rebuilding a car is a journey).
Moppie is offline   Reply With Quote
Old 10-22-2011, 05:48 AM   #5
armyblog
can some one suggest me diesel performance chips sites?
armyblog is offline   Reply With Quote
1994 f150 5.0 rebuild spoovey F Series 4 03-19-2010 06:30 PM
Engine Rebuild abc234 Aveo 1 05-17-2009 06:38 PM
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
suggestions for engine rebuild kits Pewter'01SS Camaro Discussions 3 05-13-2005 01:25 AM
parts for engine rebuild 1trickedoutdsmra Off-Topic 10 12-27-2004 08:00 PM
