Go Back   Automotive Forums .com Car Chat > MG > MGB
Old 06-01-2011, 08:53 PM   #1
jmrucker
gas guage stuck at half
Hi, one more question. my gas guage on 75 mgb is stuck at the half tank mark this car sat along time. should i just drive it and hope it breaks loose or do you think i should pull the sending unit and check if it is stuck and maybe free it up. thats in advance i appreciate the help.
jmrucker is offline   Reply With Quote
Old 06-05-2011, 06:40 AM   #2
Flash75
AF - Advisor
Re: gas guage stuck at half
Is you heat gauge working correctly? If heat gauge is OK remove the green/black wire at the sender, with ignition on temporarily ground the wire, the gauge should climb to the full position. Don't leave it grounded longer than necessary to check the gauge.
If heat gauge is good and the fuel gauge changes when grounded I would remove the sending unit and check it.
Clifton
Flash75 is offline   Reply With Quote
Old 07-03-2011, 09:52 PM   #3
thepeggasus
There is one other thing you should try before taking the extreme step of removing the sending unit. If the test suggested by Clifton worked and the gauge climbed to Full, you might still have a bad ground. This is not uncommon on MGBs. Do this test also: Connect a wire from the sending unit's grounding terminal directly to the negative pole of your battery. If your gauge now reads F, you have found your problem. Also, if the test Clifton suggested resulted in no difference in your gauge's reading, you may have a current "leak" as the result of frayed insulation or an insecure connection.
thepeggasus is offline   Reply With Quote
Gas pedal went to the floor on its own! bagem788 Traverse 8 11-08-2017 07:08 PM
2000 Taurus Fuel Pump wrong Guage Readings DCV Taurus | Taurus Wagon 3 07-04-2009 06:46 PM
gas guage stuck on full TTAmoneypit Aztek 5 10-20-2007 10:02 PM
Gas Guage Stuck @ 5/8 full M.S.Services Vitara 0 03-06-2007 10:16 PM
gas guage stuck jestersht Villager 3 04-15-2005 06:25 AM
