Go Back   Automotive Forums Car Chat > Buick > LeSabre
Old 03-31-2011, 06:03 AM
nhra78 nhra78 is offline
2002 Le Sabre Hard Start
I have a 2002 Le Sabre that I rebuilt from a salvage title about 60K miles ago. The car has 106k now. Sometimes it starts normal other times it will crank and not start. Other times it will start and die immediately then restart fine. It has never not started (yet). I thought I heard a clunk in the trunk and the car changed idle once. So I changed the fuel sending unit with a salvage yard one. Same symptoms. The car runs perfectly fine dowm the road no missing or anything. There is no check engine light on and it has never turned on the check engine or service engine light. Going to replace the fuel filter tonight. Any other ideas?
Old 03-31-2011, 07:47 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2002 Le Sabre Hard Start
Check to see if the security light is on continuously when it cranks, but will not start.
Knowledge can be communicated, but not wisdom!
Old 03-31-2011, 08:58 AM
I checked, the security light is not on while cranking. Sometimes it will not start until you let go of the key from the start to on position. I thought maybe the battery was weak (its the original) but it load tested fine. Its definately getting worse. It started to happen about a year ago then it totally went away and now its back. I love intermittent problems.
Old 03-31-2011, 10:00 AM
Scrapper Scrapper is offline
AF Premium User
on the check engine lite you could try resetting computer by neg cable of battery for abount 15mins. if its on i recomend you take it to autozone for a free test.
Old 03-31-2011, 10:08 AM
tempfixit tempfixit is offline
Have you ever checked for codes?? I would check for codes to see if there are any PENDING codes that might be helpful.
Have you checked the ignition switch since you need to at times let go of the switch in the start to run position before it will start??
Old 03-31-2011, 10:55 AM
I have not checked for codes since there was not a check engine light on. Have not checked the ignition switch. I will scan for codes when I get home tonight.
Old 04-01-2011, 05:31 AM
No codes. I don't know if the starter steals juice from the coils while starting or not but I may try a different battery even though mine tests OK its still 10 yrs old.
Old 04-01-2011, 09:11 AM
brcidd's Avatar
brcidd brcidd is offline
Put a test light on coil 12v input- see if it is lit in both "start" and "run" positions-- sounds like a bad ignition switch if it is not lit in start position.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 05:14 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
2002 325ci Hard Start. ssigur 3 Series 3 11-08-2003 05:35 AM
