| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
98 Ford, only goes into 4 wheel sometimes
Hey, just picked up a 98 ford f 150 4 X 4. We drove it and couldn't tell if the 4 X 4 was working. Put it up on jack stands, and when you switch it over, sometimes it works, others you can hear it laboring, but not engaging. Not quite a grind but close. And ideas?
Thanks Neil |
Re: 98 Ford, only goes into 4 wheel sometimes
I think the front axle itself has an electric disconnect. If it is not working, the transfer case output can't power the front wheels because the differential won't let it....
10 hours away from John Deere master certified also master certified ASE tech. Exp. in both. Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training Gave up wrenching for "Greener Pastures" Current job: RN 2010 Silverado Z71 5.3L 65xxx Wife's 2007 Suburban 1500 LTZ 5.3L 102xxx |
One up that one...
It is also vacuum activated, not electronic, so the accuator itself may not be bad, check for vacuum leaks.
there is a vacume servo on the right hand side of the diff make sure that is lubed they hang up it gets it vac from a swtch on the fire wall
