Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 09-28-2010, 01:18 PM
friesza friesza is offline
2000 Blazer running bad when cold
So how many O2 sensors are there on a 2000 blazer 4.3 4wd? My next maitenance is this....and I have had the same problem with my blazer and it seems to happen this time of year when it gets wet out...so it lead me to replace cap and rotor and it got better.
Old 09-28-2010, 04:40 PM
old_master's Avatar
old_master old_master is offline
Advisor/Moderator
Re: 2000 Blazer running bad when cold
There are 3 sensors on a 2000 4.3L engine: One close to each exhaust manifold, and one just downstream of the converter. Keep in mind that O2 sensors are ignored by the ECM until they are warmed up, (approximately 3 minutes on a stone cold engine). If the engine misfires during warm up, it's not an O2 sensor causing it. What brand distributor cap and rotor did you use? Did you put a dab of silicone dielectric grease on each terminal, (inside and out) of the cap when you installed it? Is the SES light on, or does it blink on acelleration?
You have to know how it works,
to figure out why it doesn't.
Old 09-28-2010, 05:12 PM
I was just wanting to know how many to buy...I figured out the stumbling prob last year....just can't do any work on it for a week or two as I just had abdominal surgery and cannot lean or crawl so I couldnt check to see how many I needed...but great info anyway...thanks
Old 09-28-2010, 05:54 PM
old_master's Avatar
Advisor/Moderator
Bosch part #15703 for the direct fit sensors, they're about $50.00 each. Don't waste your time or money on the universal fit sensors. Might need to use a little heat to get the old ones out... drive it until it reaches operating temp then remove them, they'll come right out. Invest in an oxygen sensor socket if you don't already have one, http://www.harborfreight.com/3-8-eig...ket-95045.html
2000 k 3500 runs bad when warm axlebender Silverado 13 10-15-2008 06:34 PM
2000 k 3500 runs bad when warm axlebender C/K 2 10-15-2008 10:16 AM
Runs Bad When Cold - Please Help! simaronde03 Windstar 4 08-11-2004 08:36 PM
S 10 Blazer wont start when cold. lanestewartsr Blazer 0 04-22-2004 08:40 PM
93 Blazer , Idles/Runs Rough when cold... O.K. hot kirbyoftville Blazer 2 12-23-2003 04:50 PM
