Old 12-22-2003, 01:09 PM
kirbyoftville kirbyoftville is offline
93 Blazer , Idles/Runs Rough when cold... O.K. hot
If you drive or run it for about ten minutes, so it's good and hot, then cut it off and come back 5 minutes later it runs fine. Just driving it doesn't make the problem go away it seems, you need to cut it off and let it sit a few minutes.
4.3 L ENGINE
maybe I should elaborate.... It skips and jumps like a car with a stuck choke, but a 93 blazer 4.3 has fuel injection right? It don't look like no carb I've ever seen. I've tried carb cleaner, did that first , but upon review of the symptoms I don't expect results from that. Has to be a sensor or something that is affected by heat, right?
Old 12-22-2003, 09:02 PM
ibhuff's Avatar
ibhuff ibhuff is offline
Re: 93 Blazer , Idles/Runs Rough when cold... O.K. hot
Has your gas been burning up faster than normal? Maybe try testing the oxygen sensor.
Old 12-23-2003, 04:50 PM
I'll try that as soon as I can get down to see my mechanic/cousin.
One new development, today was warmer than usual and at lunch time it ran fine with no preheat needed. It had been off for about 6 hours so I expected a rough start as normal. Is the O2 sensor affected by heat?
Yes , gas use is up.
Cold starting in general and runs rough when cold starting searcherrr Windstar 11 12-10-2006 11:42 PM
Seeking help for 4.0 running rough when cold, fine when at temp JeepN Wrangler 2 07-25-2006 06:13 AM
96 ram 1500 runs rough when cold 96rammer Ram Pickup | Ram SRT10 0 12-02-2004 09:00 PM
