Old 10-14-2008, 07:58 PM
axlebender axlebender is offline
2000 k 3500 runs bad when warm
Hi... I have a 2000 k 3500 that terrible when the engine is warmed up. The engine starts fine, runs good cold, no misfires detected, clean computer scan, no codes. I am thinking intake manfold gaskets. Any ideas.
Thanks
Mark
Old 10-15-2008, 09:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 k 3500 runs bad when warm
What mileage and what engine and tune up history?
Any blinking check engine light when running bad?
What is the engine vacuum reading atidle and at 2K RPM?
Did you put it on a engine capable scanner and read out all engine running data?
And check for past present and history and pending codes?
MT
Old 10-15-2008, 10:09 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
This thread is repeated in the C/K section...to which I replied the same way. They should be combined.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-15-2008, 10:10 AM
Hi... thanks for the response, the engine is a 5.7 ltr with 162,000 miles on it. There is no blinking check engine light, i have not checked engine vaccum at idle or 2000 rpm. I do believe they cheched for all codes past present and pending but i am not sure. the engine running data is as follows.
MAF in LBS 1.51
MAP in HG 8.9
IAT 37
IGN ADV 21.5
LT FTRM1(%) 0.0
ST FTRM1(%) -6.3t to -9.4
LT FTRM2(%) -1.6
ST FTRM2(%) -8.6 TO -10.2
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.160 TO 0.835
ST FTRM 11(%) -10.2 TO -11.7
O2S22(V) 0.490 TO 0.525
PTO STATUS DISEN
Thanks again for your help, the truck also started cutting in and out during acceleration like the ignition or fuel pump is cutting in and out.
Thanks again
Mark
Old 10-15-2008, 10:12 AM
Ya i didn't realize i had posted in the wrong spot. How do i combine them?
Thanks
Mark
Old 10-15-2008, 10:31 AM
MT-2500's Avatar
AF - Advisor
Make sure fuel pressure is up to specs.
Always check on the road and after warmeed up good.
Check secandary ign . good
Plugs wires cap and rotor coil .
Good Hot blue spark to all plugs?
Ac delco plugs?
Watch the camshaft retard reading on scanner.
Watch fuel trims and tempt sensors.
MT
Old 10-15-2008, 10:39 AM
Schrade Schrade is offline
Does it lope idle when warm?
Old 10-15-2008, 10:54 AM
The engine does lope when warm, it sputters shakes, when reved a bit in park its like its missing, stumbling. I will check through the ignition system plugs, wires rotor coil. I will also have a fuel pressure test performed in the next day or so and let you guys know what i find out.
Thanks again for all help i really do appreciate it.
Mark
Old 10-15-2008, 11:03 AM
Originally Posted by axlebender
The engine does lope when warm, ...
Loping idle is vacuum leak. 30 year old lawnmower, or a new car on the lot. If it sucks air where it ain't supposed to, it lopes.
Brick on pedal, block TB arm, anything to get a STEADY rpm (not necessarily no MIS-fire, you just want STEADY rpm) 1200rpms or so... Feed starting fluid spray, A LITTLE AT A TIME, EVERYWHERE. Rev increase is the leak.
In a tough spot to pinpoint? Light a book of matches, blow it out while the heads are burnin', and feed the smoke to the leak.
Old 10-15-2008, 12:09 PM
ok i'll check it for vaccum leaks, just checked fuel pressure its 56 psi through the rpm range i think this is in spec. i will also tune up the ignition system and let you guys know it turns out.
Thanks
Mark
Old 10-15-2008, 12:25 PM
Maybe it's a better idea to do the free diagnostic tests, instead of spending money blindly.
Unless you're rich and got $$$ to waste, then feel free to send me some ...
Old 10-15-2008, 12:45 PM
I had one done and the guys didn't see anything out of the ordinary, maybe i should find another shop to do it or take it to the general, although i've been trying to avoid paying the price there. There where no vacuum leaks that i could detect and no misfires showed up on the scan but it can't hurt to tune it up it doesn't cost that much. If that doen't work i guess i'll have to take it to gm.
Mark
Old 10-15-2008, 01:14 PM
MT-2500's Avatar
AF - Advisor
Thanks
Mark
Fuel pressure specs are 60/66.
What is the engine vacuum readings?
Fuel pump/pressure testing.
And always test after running a hr.
The only true test on a fuel pump is to check the direct fuel pressure from fuel pump.
A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs.
But do not run the pump at full pressure very long.
Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes
until the pump gets has run a while to check for a pump fading out after hot.
Hard to start cold and fuel pressure testing guide line.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak in system.
Post back fuel pressure readings.
MT
Old 10-15-2008, 06:34 PM
ok i'll check as much of this stuff as i can on my own in the next day or two and let you know what i find out. Just tried the truck again now its running like hell will still start but its impossible to drive. I can here it popping in the the tail pipe sounds like an ignition miss but it could be a fuel issue too.
Thanks
Mark
