Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix
Old 08-31-2010, 03:39 PM
wango wango is offline
1989 pontiac gran prix
Read some past forums. Car has a problem won't stay running after warm up for nine minutes. Just like somebody turned of the key. I have been through the sensor routine, fuel checks, and vac checks, and icm changed, coil checks, any ideas.
richtazz, wounderd if you had a resolution from your past.
Old 08-31-2010, 09:12 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 1989 pontiac gran prix
What motor in your 1989?
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
Old 09-01-2010, 01:48 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Sorry Wango, but with close to 10,000 posts, I'm not sure as to what past you are referring. Is your Check Engine light on? If so have you pulled the codes stored? If not, the most common cause of this issue is the ECM (Electronic Control Module) commonly referred to as the computer. On this particular car, they are mounted under the hood, therefore being subjected to moisture, salt, etc...(especially since you're in MI) If the OEM part number on your ECM is 1227727, there is a very good chance it's your issue, as it the most problematic of those used in this particular car.
Old 09-01-2010, 04:41 PM
Yes the ecm is a 1227727. I will check all connections on computer. It is reading o.23volts on the map sensor while backprobe on c & a. and does not raise while engine is at idle. The a & b test 4.01 on the map stays the same while engine is running. Thi is a sign of possible ecm. Also about the time the car shuts down the car iswarmed up. Would the temp selenoid swicth for the fan have an efect on this problem.
Old 09-01-2010, 04:46 PM
PS. I did have a friend with a snap scanner dianosed ecm still good. First code thrown was a temp coolant sensor bad and changed that allready cleared ot code since. Rechecked diag or code but none showing
Old 09-01-2010, 04:54 PM
I have not located the cam sensor yet on this 2.8L for testing but wold like to. Do you have any Ideas where it is. According to chiltons it's under the power steering pump. Hmm! The chiltons I have is not specific on this engine it just mentions the 3.1m.
Old 09-01-2010, 06:09 PM
tblake's Avatar
In God We Trust
It should be in that general area, on the 3100 you need to remove the PS pump to gain access (and see) the cam sensor.
Did you do the ECM tap test? With the car running smack the ECM a couple times with the palm of your hand. Any change in idle or stall/hickup, and the ECM is toast.
1995 Pontiac Gran Prix broken hood release cable. bites Grand Prix 2 01-25-2010 08:03 PM
1995 Pontiac Gran Prix 3.1L engine whine bites Grand Prix 2 01-25-2010 08:00 PM
2002 pontiac gran prix 3.1 power steering pump BIGPETEG24 Grand Prix 2 01-25-2010 07:12 PM
92 Pontiac Gran Prix weeb3j Grand Prix 3 09-15-2007 03:14 PM
Mr. Civic's '95 Ex vs. 2000ish Pontiac Gran Prix Rampart Crawler Street/Track Racing Stories! 1 05-22-2005 02:51 AM
