Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-28-2004, 04:45 PM   #1
Kent L. Nelson
1999 Cherokee Engine Fan will not shut off
The Electric radiator fan will not shut off. I unpluged it at the radiator. can anyone tell me where the relay is, or the switch that operates the fan is. I shut off the Jeep and the electric fan keeps running, even when the engine temp is low. Any ideas? Any help?
Thanks
Kent L. Nelson is offline   Reply With Quote
Old 09-16-2004, 03:12 AM   #2
dksob81
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 1999 Cherokee Engine Fan will not shut off
I have no clue, I do know that the fan could continue to run for an hour after shutting the engine off due to high temp heat. but u said it doesn't get that hot, I have no clue what could cause this.
dksob81 is offline   Reply With Quote
Old 09-16-2004, 10:51 PM   #3
xj31
the relay is stuck.its in the power distribution center or pdc .thats the fuse box under the hood by the battery.
xj31 is offline   Reply With Quote
Old 02-08-2005, 12:54 PM   #4
RajinAzn
Send a message via AIM to RajinAzn
i ahd the same problem, but after pulling the relay, the fan will not turn on, even if the car is overheating... i'm also gettign this stem-like stuff out of the radiator... like, it's not completel clear, and i can see like this rainboqish coloring in there... any ideas?
RajinAzn is offline   Reply With Quote
Old 03-13-2005, 04:45 PM   #5
kvr
Thanks
From kvr= /The coolant fan is operated by the pcm, but there is a relay located underneath the passenger side head light, which you can see, just look down and to the right of the fuse conpartment to the front of the fender, its a pain to get at, its a four prong plug with two mounting screws, the relay is about 50 to 60 dollars from your jeep dealer, its not listed at any auto parts yet, at least none that i know dealer item i guess. this is if your jeep is a 4.0.
kvr is offline   Reply With Quote
Old 03-09-2007, 04:44 AM   #6
mac_daddy
It's the fan control relay and it's located under the passenger side headlight. In order to get to it you have to take off the front bumper and facia OR do what I did and take your dremmel and cut a hole in the plastic under the headlight big enough to remove it. It's not easy to find but trust me it's there and it's definately your problem. I just covered the hole back up with a scrap piece of plastic and some duct tape. Works like a charm!
mac_daddy is offline   Reply With Quote
Radiator fan will not shut off pontoonman Windstar 1 02-16-2010 01:01 PM
96 Taurus radiator fan will not shut off 7string Taurus | Taurus Wagon 4 10-16-2008 06:29 PM
AC blower fan will not shut off... ghink LeSabre 6 08-18-2006 04:24 AM
My cooling fan will not shut off after driving. Any Ideas? dstew42 Cabrio 2 10-15-2005 12:35 PM
Fan will not shut off? dpbrowne SC/SL/SW 1 04-15-2004 05:10 AM
